Reply
Old 20th Sep 2023, 12:03 pm   #21
Station X
Station X's Avatar
Default Re: RF gain control on AR88 not working
Good to know it's working again. Be sure to make a good job of resoldering R56 or you could be saying goodbye to your output transformer should you use the set with headphones.
Graham. Forum Moderator
Station X is offline   Reply With Quote
Old 20th Sep 2023, 3:45 pm   #22
Radio Wrangler
Radio Wrangler's Avatar
But before a new problem arises, have you done the due diligence on the DC blocking and tone correction capacitors?
Sorry for pestering but any of these wonder-components can destroy your audio output stage, both valve and transformer with a fighting chance at taking out the mains transformer. Now is the exact time you would want to travel back to after the event, if you could hitch a ride on a passing time machine.
Old 20th Sep 2023, 6:34 pm   #23
G6Tanuki
G6Tanuki's Avatar
And while you're in there, consider doing my output-transformer-saving mod using a couple of wire-ended NE-2 neons across the primary too....
Neons are cheap; replacement output trannies for the AR-88 are not.
I played a blank tape at full volume. The mime-artiste who lives next door complained.
Old 21st Sep 2023, 12:49 am   #24
Silicon
You also need to find out why the negative bias voltage is so high.
Silicon is offline   Reply With Quote
Old 26th Sep 2023, 10:54 am   #25
Alan Bain
In case anyone finds it useful - here is a clear scan of the CR88 wiring diagram. I have no idea where this came from originally as when I was fixing my AR88 I had to rely on the hard to read one from BAMA.
This morning the cat knocked down a file which contained details of projects I had worked on long ago as a student and in it there was an AR88 manual and this original sheet of wiring diagram.
Uploaded as zip to stop resolution being reduced!
Alan
Alan Bain is offline   Reply With Quote
Reply
