Reply
Old 17th Sep 2023, 6:31 pm   #1
Martin Bush
Martin Bush's Avatar
Default Cassette playing fast
Hi
I have just taken delivery of a really nice radio cassette courtesy of the forum. It's in wonderful condition and works well.
However, to my ears, the cassette I have played on it so far sounds fractionally fast.
I've not had time yet to clean the heads, roller, capstan, but wanted to ask if this is likely to remedy the issue? I've read elsewhere that if the pinch roller/ capstan aren't quite doing their job it can result in too-fast playback.
The tape in question is an album I am familiar with from CD and it sounds slightly sharp to me. It's a new pre-recorded cassette.
Is it live, or is it... no, it's live actually...
Martin Bush is offline   Reply With Quote
Old 17th Sep 2023, 7:03 pm   #2
Beobloke
Default Re: Cassette playing fast
More likely that the regulator pot on the motor needs a minor tweak.
Beobloke is offline   Reply With Quote
Old 17th Sep 2023, 7:54 pm   #3
paulsherwin
paulsherwin's Avatar
Obtain a source of sine wave tone, copy it to a cassette using a known accurately aligned deck, then adjust the speed for zero beat while playing the original source on a computer or CD player.
paulsherwin is offline   Reply With Quote
Old 17th Sep 2023, 10:12 pm   #4
ben
ben's Avatar
Check the obvious first: buildup of crud on the capstan or inside on the motor pulley?
This kind of equipment was never exactly precise, so may need a slight tweak to the speed pot (often part of the motor, so use insulated screwdriver)
Regards,
Ben.
ben is offline   Reply With Quote
Old 17th Sep 2023, 11:39 pm   #5
Martin Bush
Thanks chaps. I have cleaned the capstan, pinch roller etc and, dare I say it, it seems to be running well now.
This machine is quite a nice one so I may get it professionally serviced at some point. I have enough experience now to know that I often fix one fault and create another. Time to quit while I am ahead
Old 22nd Sep 2023, 9:41 am   #6
pazuzu72
Hi, I had a friend record a 3Khz tone on a quartz deck. I think it should be reliable.
pazuzu72 is offline   Reply With Quote
Reply
