Reply
Old 16th Sep 2023, 5:49 pm   #1
vinrads
Default Personal cassette player rubbish playing music.
I have several makes of these ,all serviced new belts etc ,all of them seem to have excessive wow and flutter or maybe just wow , not so noticeable on speech but terrible when playing music , these run on a 1.5 volt so there must a dc to dc converter , has any one had this problem . Mick.
vinrads is offline   Reply With Quote
Old 16th Sep 2023, 7:26 pm   #2
Ted Kendall
Default Re: Personal cassette player rubbish playing music.
I think this may be a case of everything having had to be "just so" when the thing was new to give acceptable results - lubrication, belt compliance and thickness (some are very thin, on Sony bi-directionals for instance) and all drive surfaces scrupulously clean. Dissolving belts can leave remnants of themselves deep in grooves in the pulleys, where they play havoc. The other favourite is a take-up clutch binding or a sticky feed hub. I think the market tolerated pretty poor w&f performance for the sake of portability - at least at first, hence the introduction of direct drive Walkmans, whose stability is most welcome!
Ted Kendall is online now   Reply With Quote
Old 16th Sep 2023, 8:05 pm   #3
DMcMahon
DMcMahon's Avatar
I vaguely remember some time back some threads about problems with some Sony portables (maybe Walkman) related to the DC to the DC converter module but I don't think they were single 1.5V battery units so probably not relevant here.
DMcMahon is offline   Reply With Quote
Old 16th Sep 2023, 8:41 pm   #4
paulsherwin
paulsherwin's Avatar
This sounds very odd. I've used a range of Walkman type players over the last 40 years, and apart from the dirt cheap ones at the very bottom of the market they've all sounded surprisingly good - not up to the performance of a half decent cassette deck, but that's hardly surprising given the design constraints.
paulsherwin is offline   Reply With Quote
Old 17th Sep 2023, 10:14 pm   #5
ben
ben's Avatar
My money is on the replacement belts being out of tolerance. There is some utter rubbish being sold online, some seem like off-cuts of bicycle inner tubes!
Regards,
Ben.
ben is offline   Reply With Quote
Old 18th Sep 2023, 9:34 am   #6
vinrads
I did notice that Ben if you pull the belt through your fingers you can feel the imperfections this was in a job lot from China ,all mine were purchased from Germany especially made for the model in question . Mick.
Old 18th Sep 2023, 9:48 am   #7
stevehertz
stevehertz's Avatar
As Ted says these things rely on each and every component being up to scratch. Double check?
Last edited by Station X; 18th Sep 2023 at 10:18 am. Reason: It is not necessary to quote the previous post in full.
stevehertz is offline   Reply With Quote
Reply
