Reply
Old 16th Sep 2023, 11:23 am   #1
feathers632
Default Uher 4200 report stereo IC bottom panel screw
The unit I restored didn't have a bottom plate screw. It looks like it would turn and lock. Anyone know if it's possible to source one or if substitute possible?
Thanks
feathers632 is offline   Reply With Quote
Old 16th Sep 2023, 2:02 pm   #2
TIMTAPE
Default Re: Uher 4200 report stereo IC bottom panel screw
I believe it's all plastic. It may have broken for that reason. I had the same problem. I think I just used a standard metric screw and washer.
TIMTAPE is offline   Reply With Quote
Old 16th Sep 2023, 3:21 pm   #3
DMcMahon
DMcMahon's Avatar
I think you mean the underside/bottom cover that is retained by a single quarter turn locking screw.
The first 2 photos show the metal version with retaining circlip as fitted to a 4200 (not sure at the moment which exact model).
The 3rd and 4th photos show a plastic version from a 4000 Report Monitor, I cannot see how to remove the large plastic washer to be able to remove the plastic locking screw ?
Unfortunately I do not know of source for either version or a possible subsitute.
ID:	285072   Click image for larger version
ID:	285073   Click image for larger version
ID:	285074   Click image for larger version
DMcMahon is offline   Reply With Quote
Old 16th Sep 2023, 3:45 pm   #4
feathers632
@Timtape Plastic has a habit of doing that especially in that sort of role.
@DMcMahon You may not know of a source but those photos along with dimensions means I should be able to fabricate one. 3d print in metal or mod a metal rod.
Thanks for the help!
Old 16th Sep 2023, 4:40 pm   #5
feathers632
Hi @TIMTAPE
That's why we don't use plastic for some applications
Hi @DMcMahon, your photos give me a good understanding of how it works and the dimensions. I should be able to 3d print in metal or fabricate.
Thanks!
Old 16th Sep 2023, 9:09 pm   #6
DMcMahon
DMcMahon's Avatar
From a 4400 Report Stereo IC which I assume should be the same as the 4200.
Photo attached showing the nylon 1/4 turn chassis female fastener.
Old 16th Sep 2023, 9:19 pm   #7
DMcMahon
DMcMahon's Avatar
Excellent that you can 3D print it, I wish I had that ability and knowledge.
If you need any more details/dimensions then let me know.
Old 17th Sep 2023, 7:17 pm   #8
Kentode
Kentode's Avatar
Try looking for Dzuz quarter turn fasteners on eBay...
Regards, Ken.
BVWS member
Kentode is offline   Reply With Quote
Old 18th Sep 2023, 9:21 am   #9
DMcMahon
DMcMahon's Avatar
Normally spelt Dzus.
Old 18th Sep 2023, 10:30 am   #10
Kentode
Kentode's Avatar
I sit corrected! Thanks David.
Regards, Ken.
BVWS member
Old 22nd Sep 2023, 2:32 pm   #11
Uncle Bulgaria
Uncle Bulgaria's Avatar
I'm not sure if you have the screw or the nylon clip missing. The screw is metal and retained as shown in DMcMahon's pictures.
In 2011 I bought one of those nylon quarter-turn clips from Johann Gruber at Uher Service.
The website's still up and there's a new one at uher-service.com, too.
SDS Uher Service have sent me Uher cassette parts in the last year.
I think it'd be worth contacting one of them.
Uncle Bulgaria is offline   Reply With Quote
Reply
