Reply
Old 15th Sep 2023, 10:05 am   #21
Big Loon
Default Re: Gramdeck.
There was an article on the gramndeck in a recent issue of "Hi-Fi World" magazine (yes I do read such publications!). Time permitting over the next few days I will look it out and scan it. Sadly, said magazine has gone under and is no longer being published.
BL
Big Loon is offline   Reply With Quote
Old 15th Sep 2023, 10:10 am   #22
Heatercathodeshort
Heatercathodeshort's Avatar
I have a Gramdeck somewhere complete with the pre amplifier powered by a PP9. I've never tried it but I suspect it 'worked'. It is surprisingly well engineered.
The domestic tape recorder must have been the most expensive household gadget ever. Bought usually at Christmas, played for a couple of hours recording drunken Grandad, Gran singing the Lambeth Walk, baby screaming and some radio programmes recorded via the microphone with appalling quality.
They were soon put on top of the wardrobe and forgotten. Around £40-50 wasted at a time when a £ was a £. The Gramdeck filled the amusement factor for a relatively low sum. Maybe the drop in price of good simple recorders fitted with the BSR TD2 deck and the arrival of the Philips cassette finished them off. John.
Heatercathodeshort is offline   Reply With Quote
Old 15th Sep 2023, 10:41 am   #23
mickm3for
Hi i have a new one in box brought from Harrods complete with invoice. Never taken it out of box Mick
mickm3for is offline   Reply With Quote
Old 15th Sep 2023, 2:46 pm   #24
lesmw0sec
I had one of those prior to starting on proper tape decks. It worked very well and had a good deal of use. The replay amplifier was a tad noisy though.
lesmw0sec is offline   Reply With Quote
Old 15th Sep 2023, 7:54 pm   #25
Tractorfan
Tractorfan's Avatar
Smile Re: Gramdeck.
Here's a couple of photos of my Gramdeck. I'll get around to trying out one of these days.
I noticed today thet the take up spindle has no splines on it, so curious how it drives the spool?
The supply spool had a felt 'washer' under it to provide a bit of back tension. Revox, it is not!
Cheers, Pete.
ID:	285034   Click image for larger version
ID:	285035   Click image for larger version
ID:	285036   Click image for larger version
ID:	285037   Click image for larger version
"Hello?, Yes, I'm on the train, I might lose the signal soon as we're just going into a tunn..."
Tractorfan is offline   Reply With Quote
Old 15th Sep 2023, 9:04 pm   #26
Ted Kendall
The take-up hub used another felt washer to provide clutch action, which was quite effective. Rewind was effected with a handle which dropped into the hole in the feed spindle. Back tension in this mode was provided by a hefty "rewind weight" which sat on the other reel...
Ted Kendall is offline   Reply With Quote
Old 15th Sep 2023, 9:10 pm   #27
mole42uk
mole42uk's Avatar
I had a couple of these, passed them on at one of the swapmeets some years ago. The device worked very well, much better than it looked as though it would! The seperate amplifier had a proper AC bias / erase oscillator too.
Richard
Index:
mole42uk is offline   Reply With Quote
Old 15th Sep 2023, 9:45 pm   #28
kalee20
Originally Posted by Ted Kendall View Post
Despite permanent magnet erase...
Tractorfan's photos certainly do show a coil... but we have two different statements here! So is the oscillator for bias only, or is it bias and AC erase?
kalee20 is offline   Reply With Quote
Old 15th Sep 2023, 10:27 pm   #29
mole42uk
mole42uk's Avatar
I am mistaken about the erase, it's been a few years....but here's a leaflet detailing some of the features: https://reel-reel.com/tape-recorder/gramdeck/
Richard
Index:
Old 15th Sep 2023, 10:43 pm   #30
DMcMahon
DMcMahon's Avatar
The Gramdeck service information under Instant Downloads also explains that it has permanent magnet erase & AC bias for the Record head (Record/Play head).
DMcMahon is offline   Reply With Quote
Old 15th Sep 2023, 11:19 pm   #31
Boulevardier
Interesting that the Gramdeck was built to the "rigid requirements of the Royal Radar Establishment, UK". Strange that the RRE chose to use them - surely they could have afforded Ferrographs!
Mike
Boulevardier is offline   Reply With Quote
Old 16th Sep 2023, 11:51 am   #32
DMcMahon
DMcMahon's Avatar
The Gramdeck is covered in H.W. Hellyer's " Tape Recorder Servicing Manual" book.
Old 16th Sep 2023, 12:13 pm   #33
G6Tanuki
G6Tanuki's Avatar
I wonder if any original Gramdeck recordings made in the early 60s have survived??
The whole thing is fascinating to me, one of the possible uses of the variable speeds that comes to mind is for learning Morse, record something at the highest speed then play it back at the lowest speed so that you could read it and then as your skills improved move on to the higher speeds..
TURN IT UP! [I can't hear the Guitar] - TMBG.
Old 16th Sep 2023, 12:28 pm   #34
Vintage Engr
I remember these very well, a friend bought one. The quality, at that time wasn't bad, but the permanent magnet erase, (just like some very early portable RR e.g. Grundig Cub, & later cassette recorders) did the job... at the price of noise.
Fast forward & rewind was a bit of a faff.
The microphone that came with it looked impressive, but, as with many recorders of that period, it was a crystal mic, so therefore Hi-z & the lead had to be kept short, & out of the way of the gram motor. I was more used to Reslo ribbons.
David.
Vintage Engr is offline   Reply With Quote
Old 16th Sep 2023, 7:00 pm   #35
Ted Kendall
High impedance, certainly, as far as I remember, but the Lustraphone Lustrette usually supplied was a moving coil instrument.
Reply
