Reply
Old 24th Aug 2023, 9:06 pm   #1
Stevemac
Default BP413 Receiver
Today I have just had delivered the strangest receiver I have ever seen. It is a Reception Set B.P.413 (ZA22773) made during the war and is very small with a wooden case. Seems to be a similar kind of ‘utility’ receiver to one that was renovated on Retro, Electro, workshop last week. Has 4 valves ARTP2, ARP12, AR8, CV65 and works from batteries like the WS38 set. Civilian utility broadcast receivers from the war all had just MW or MW and LW. This one has a single band, but is 1.4Mhz – 4.0Mhz (160m and 80m) It has a built in frame aerial hidden around the front panel.
I have found very little about this receiver, except that someone suggested that it was made for use during the D Day landings to listen for instructions from the nearby battleships.
An interesting project.
Anyone know anything about this little gem?
ID:	283948   Click image for larger version
ID:	283949   Click image for larger version
Stevemac is offline   Reply With Quote
Old 24th Aug 2023, 9:49 pm   #2
Cobaltblue
Cobaltblue's Avatar
Default Re: BP413 Receiver
Hi Steve and welcome to the forum
Responders please be mindful that no discussion of the Retro Electro Workshop.
There is a previous thread about this set here: https://www.vintage-radio.net/forum/...d.php?t=106789
Mike T
Don't care if it was a bargain why's it in my kitchen
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is offline   Reply With Quote
Old 24th Sep 2023, 6:10 pm   #3
Stevemac
Default Renovated BP413 Receiver
Following my earlier post, I have now renovated the very unusual Philco BP413 receiver.
This receiver was built in 1944 and was a utility receiver that has a single band of 1.4mhz - 4.2Mhz. This would be 80m and 40m, but I think it may have been intended for use of monitoring the marine band / trawler band. From what I have found out, they were used during the beach landings and carried in a waterproof back pack by troops. They were probably used to listen to the British Forces Radio transmissions after the landings.
I have replaced all the capacitors and some resistors and the radio works well with its quite large internal speaker. The radio was powered by the same battery used by the WS38 radio. I have now built in a Mains Battery Eliminator circuit to power the BP413.
The original radio when I got it had been painted with rosewood varnish, but the original colour was a dull battleship grey. I decided to strip it all down to the wood and paint with matt black. This makes it look much better.
Steve G4AQB
Reply
