#141 |
I have worked out how to dismantle (and reassemble
![]() Place it on the bench standing on the solenoid unit with the 'nose' pointing upwards. Take out the 2 small screws holding the ribbon guide and take that off. Remove the 2 larger screws that hold the mounting bracket, and remove that. Remove the 2 small, but longer, screws in the flange of the 'nose unit'. Take that out (do not dismantle it). Lift off the heatsink block. So far that's in the manual. Now : Turn the solenoid unit over. The rear plate is clearly retained under some plastic tabs. Rotate the plate anticlockwise to free it and _carefully_ lift it off. 'Carefully' as there are 7 tiny compression springs around the edge. Remove those springs with non-magnetic tweezers. Be warned if your tweezers are magnetised you will use language unsuitable for this forum. 6 screws are now exposed. Undo the 3 deeply recessed ones in the middle. Then lift off the complete armature unit. This does come apart with the other 3 screws but there's no point normally. Recover the plastic insulator, then lift off the PCB with the coils.Under it is a thin plastic washer and another insulator. I am not sure how practical it would be to re-wind the coils. There are no bobbins or formers. They seem to have been made with that self-sticking wire used for deflection coils, etc. But it might be possble. |
#142 | |
![]() Quote:
