#41 |
It is a spool of ribbon, not a cartridge, so there's a good chance you'll be able to get something that will work. I _think_ the Epson TX80 used the same mechanism.
AFAIK, yes, the 2022 is the tractor feed model, the 2023 the friction feed one. There is no sane way to convert one to the other. The link that grounds one of the port pins used to drive the stepper motor in the former model is detected by the firmware at power-up and enables the friction feed solenoid driver routine, etc. So I _think_ the ROM is the same in both models. Incidentally I was given my 2023 because the bottom pin in the printhead was broken. I did get a replacement printhead in the end but before that I just soldered a jumper on the printhead connector to wire-OR the drivers for the bottom 2 pins. The output was a bit odd, but readable, and a lot better than no printer at all. |
#42 | |
Morning. Work meetings at 08:30. Ugh.
From the -other- end of R5 down to ground. Meter on resistance, mains plug inserted but switched off at the socket, black probe on earth, red on R5 - 2.2kΩ Resistance from 7A (5) to 0V - also 2.2kΩ Resistance from 7A (10) to 0V - 18.7kΩ There doesn't seem to be a 6B on this board - I'll annotate the drawing that is in that PDF in a while to try to properly locate everything. Colin. Quote:
#43 | |
I've not looked into these (apart from downloading them just in case) but these seem to be the ROMs:
https://zimmers.net/anonftp/pub/cbm/...022/index.html Colin. Quote:
#44 | |
![]() Quote:
#45 | |
This is definitively an EPSON 3110 inside - see attached phot.
Colin. Quote:
#46 | |
![]() Quote:
#47 | |
![]() Quote:
Well that's very confusing that on the Schematic they've referenced that (Actually turns-out to be the mechanism) number on, isn't actually the one being used with it in this case. And it might have been more logical if they'd put the Control board part no. in the title, instead, being as they both use the same 3110 mechanism. But I guess they just reprinted the Epson one, where Epson did have different control boards for their different mechanisms. (Although, using the same main 'Commodore' IC's, and having the IEEE-488 interface, would rather indicate that this too was really a Commodore design, just made by Epson for them) However, Commodore calling their own version of the control board 'Epson Printer Logic. is also a bit confusing, when in a manual for ones that all used the same Epson mechanism, but different control board makes / designs. But again, I guess Commodore had different control boards for different mechanism manufacturers (if they were using any others at that point), so had labelled their schematic as being for an Epson make (But model of mech. would also have been helpful!) I'm still wondering what physical differences there are between the 202x and 302x models, as the external pictures I found looked rather similar. |
#48 | ||
Resistance between 4B pin 6 and 0V - 6.4kΩ.
Colin. Quote:
#49 | ||
Actual documentation for this printer (3022) is very difficult to find - most Commodore equipment has been scanned/saved but the 3022 seems to be an exception.
The only document I can find that explicitly has the 3022 in its title is below (but is in German and has no schematics in it): http://www.zimmers.net/anonftp/pub/c..._3022_3023.pdf Colin. Quote:
#50 |
As an aside, Epson made an optional IEEE-488 interface board for some of their printers (MX80,etc). But it used ASCII, not PETSCII. When I first looked at the Commodore service manual mentioned in this thread, I thought the Epson board schematic was just a reprint of an Epson centronics-interfaced printer, for reference. It isn't of course.
AFIAK the only difference between the 2022 and 3022 is the number printed on the case. Commodore wanted to make it seem applicable to the later series of PETs. They did the same sort of trick with their disk units too. |
#51 | ||
![]() Quote:
I did the WD-40 trick several times, and it can result in a bit messy prints to start with, as excess WD-40 goes onto paper (even after trying to eliminate excess from inside the cartridge) I expect there are better solvents to use, to redistribute ink from unused upper / lower areas of the ribbon. It would also probably be better to use actual ink, but excess of that would no doubt make a lot more mess so can't just poor that across the ribbon. It might be possibly to make a re-inking device, with an ink-soaked foam roller in contact with the ribbon, as it is fed over this. Genuine Epson etc ribbons probably lasted longer, but I doubt any will be too good after nearly 40years! |
#52 | |
I asked this question on a Facebook group a while back and got the following reply:
"I believe all the 30xx model numbers are the European versions on the 20xx line. When the PETs with full size keyboards were released, they kept the 2001 name and 20xx series in the US but changed to 3000 series in Europe. The 3016 is the same as the 2001-16N and the 3040 floppy drive is the same as the 2040." Colin. Quote:
#53 | |
![]() Quote:
And what voltage do you have on 4B (5)? Last edited by SiriusHardware; 18th Aug 2023 at 11:54 am. |
#54 |
#55 | |
![]() Quote:
Question for Tony, most likely? As far as I can make out the IFC input on the IEEE488 interface is biased by a 3K3/6K8 voltage divider to about 2/3 of 5V which in the eyes of gate 4B 4/5/6 will be a logic '1' and will result in a low output state on IC 4B (6) and therefore applied to the input of the reset timer circuit. Does the printer need to be connected to an actual IEEE488 host in order to see a 'low' state on the IFC input? |
#56 | ||
According to this I believe the IFC pin to be pin 9 - is that correct?
Colin. Quote:
#57 |
And Colin, I'm assuming that all checks and tests since this thread started have been with the printer stand-alone and not connected to either of the PETs. Do you have a printer cable?
Yes, the IFC pin of the IEE488 connector looks to be pin 9. |
#58 |
Yes - all tests have been carried out with no cable connected.
I have a few and have already tried connecting to the PET with no joy but cann again. Colin. |
#59 |
Apologies - fr the record I meant to add this link:
https://en.wikipedia.org/wiki/IEEE-488 All continuity checks out OK between 4B pin 5, 7B pin 15 and Pin 9 of the IEEE port. Colin. |
#60 |
Can you (...always with power off on both units) connect the printer to one of the PETs, turn the PET and printer on and check the voltage on 4B (5) again?
Just heading off for lunch. |
