#21 |
Location: Near Lichfield, Staffordshire, UK, most of the time and Crystal Palace, S London, some of the time..
Once again, sorry for the delay.
As an undergraduate I had a friend who synthethised a Pye Vanguard, somehow, whilst interesting I doubt I would do that; I am probably not clever enough anyway. The DDS route also seems to have too many potential problems, so it will be time to go fossil hunting and see what old rocks I can find. I was starting to form a list of things that use 44Mhz HC25U and the Daiwa and Trio rigs are all I had managed to remember from my dubious past. Time for some more digging through the historical mag pdf's on line then look up the radios in question, it all keeps me out of mischief. Thank you for the offer of a crystal loan Jon, I think I am convinced enough of it being the crystal and my partners current health means I doubt I will be wandering off onto any high spots this summer. I had heard of krystaly, and whilst they do not list HC25U, along with the others it offers another avenue, so thank you both. There is also Vincent to try as well. 73 Ian |
#22 | |
![]() Quote:
B
#23 |
By accident I also came across David RW's suggestion that you could short out the crystal socket of a Pye Cambridge and run it as a VFO with the pulling coil.
My 4m one heard quite a few fire brigade channels that way. Good luck on the search for 44MHz crystals. I don't think you will find from Icom (IC22 & IC215 etc were 15MHz fundamental) or Yaesu ( I only know FT202 which also used fundamental) and I suspect Standard were the same. Kenpro KP202 maybe? Last edited by Jon_G4MDC; 21st Jul 2023 at 9:01 am. |
#24 | |
![]() Quote:
B
#25 |
Yes Bazz- I didn't mean to imply that it was good enough to use for the long term. Actually it was hellishly tweaky but by keeping up the adjustments you could follow what was going on.
#26 |
Rather than leave this as a cliff hanger, I finally tracked down a suitable crystal, which arrived last week and it is now fitted and the old rig working again.
![]() Thank you all. Ian |
#27 |
Well done Ian. Patience paid off!
