Old 24th Sep 2023, 12:51 am   #1
Dazz100
Dazz100's Avatar
Default 2023 Options for Capacitor Reformer/Tester
Hi
A capacitor reformer is a key item of equipment missing from my lab. There are a number of DIY designs for capacitor reformer/testing circuits floating around the internet, including on this site:
https://www.vintage-radio.com/projec...-reformer.html
and
https://www.vintage-radio.net/forum/...d.php?t=195127
The Silicon Chip Aug 2010 design still looks like the premium solution and the one I think I might build:
https://www.siliconchip.com.au/Issue...r+%2526+Tester
but there are others.
I found this simple one : https://www.pcbway.com/project/share..._0b3de257.html
Have I missed better options?
Dazz100 is offline   Reply With Quote
Old 25th Sep 2023, 11:11 am   #2
McMurdo
McMurdo's Avatar
Default Re: 2023 Options for Capacitor Reformer/Tester
I just use a small light bulb in series with a DC supply and let it run intil the current has gone to nothing and/or the voltage on the capacitor is at its working voltage, no microprocessors involved of any sort
Kevin
McMurdo is offline   Reply With Quote
Old 25th Sep 2023, 4:37 pm   #3
David G4EBT
David G4EBT's Avatar
Back in 2009 I built the Capacitor Reformer which was initially published in Radio Bygones, June/July 2008, and later in the Winter 2008 BVWS Bulletin, which can be downloaded from this link:
https://www.bvws.org.uk/publications...olume33number4
The reformer has given good service for fourteen years now, and to my mind, strikes a sensible balance between simpler 'no frills' designs, and 'OTT' designs such as Silicon Chip. Most of it is point-to-point wiring, but I etched a little PCB along the lines of that in the article, and a little tagboard.
For the power supply, it uses two back-to-back transformers, each with two 6V 1Amp windings. That arrangement provides both the HT and the LT for powering the digital panel meter. Some constructors might wish to cull a transformer from a scrap radio, and the article explains that option, but I used two new 6 Volt transformers coupled back to back (that is with the secondaries coupled together, so you put 240V into one transformer, and get 240V out of the other. A doubler circuit uplifts that to 500V (adjustable).
I obtained the transformers from ESR Electronics, a most helpful firm I’ve used many times over the years: Side Tag Transformer 0 - 6, 0 - 6V (2 x 1A) Order Code 301-045 £8.88 plus VAT + P&P: http://www.esr.co.uk/electronics/product...ormers.htm
The IRFBE20PBF MOSFET is available and in stock from RS for 67p Inc VAT + P&P at this link:
http://uk.rs-online.com/web/p/mosfet-tra...s/5429535/
The circuit in the BVWS Bulletin wasn't very clear, and contained a small error in that digital panel meters cannot share the same ground as that which the meter is measuring. Two meters are used in the design - a 0 to 10mA analogue meter for monitoring the current, and a 0 - 500V digital meter from monitoring the reformer Voltage.
Also, the original circuit didn't make it very clear how the 'Set Current' switch (SW3) was wired. I've attached a clear copy of the circuit, with both the grounding error of the 500V meter clarified, and the S3 wiring shown in green.
The article gives useful advice on the reforming process which I typed up and have attached below, which hopefully, if printed off, will be more legible.
With thanks to the designer, forum member Stef Niewiadomski, AKA 'Saddlestone Man'
Hope that's of interest.
Name:	CIRCUIT CLARIFICATION  OF SW2 WIRING.jpg
ID:	285579   Click image for larger version
Name:	User Instructions.jpg
ID:	285580   Click image for larger version
Name:	Capacitor Reformer Front View2_edited-1.jpg
ID:	285581   Click image for larger version
Name:	Capacitor Reformer inside view2_edited-1.jpg
David.
BVWS Member.
G-QRP Club member 1339.
David G4EBT is online now   Reply With Quote
Old 25th Sep 2023, 5:46 pm   #4
Uncle Bulgaria
Uncle Bulgaria's Avatar
I've built the Silicon Chip one ('Everyday Practical Electronics' over here). They sell the board so it's straightforward. My only difficulty was making the transformer, but I got help from here to hold my hand through that. You'll find it rather easier getting the relevant Jaycar part down under, I expect.
It works well.
Uncle Bulgaria is offline   Reply With Quote
Old 26th Sep 2023, 7:48 am   #5
Dazz100
Dazz100's Avatar
It works well.
The Silicon Chip option looks good to me. The hurdle I face is the cost. The magazine shop charges $A10 for each of the two magazines. I only need the issue with the BOM, transformer winding instructions and circuit diagram, but I don't know which month(s) that is. Do I need both Aug and Sep issues? A programmed PIC is $A15. The PCB is $A20. Adding shipping and that comes to $A70 before buying parts.
Buying a cheap Chinese PIC programmer and blank chip is slightly cheaper than buying the programmed chip.
Industrial Solutions (Radio Spares), element14 (Farnell) and Digikey all sell into New Zealand, but the shipping cost makes small orders extremely expensive. The order has to be valuable enough to qualify for zero shipping cost.
I probably have most of the parts already, including the ferrite core and case.
Any I am missing are probably stocked by Jaycar that are just down the road.
Dazz
Why make something simple when you make it complicated AND get it to work?
Old 26th Sep 2023, 12:31 pm   #6
Uncle Bulgaria
I programmed the blank PIC I bought using a programmer given away by a member here, which did help reduce the cost. I'd pass on the PICKit programmer except it's packed away somewhere while house-building. The parts list is all Jaycar as it's from the Silicon Chip magazine originally.
I got the magazine from the Internet Archive and have attached a PDF I made of the construction articles. The PCB is unavoidable (and I don't mind paying for a nice PCB when they did all the work on the article!)
File Type: pdf Capacitor_Reformer_Circuit_Diagram.pdf (222.5 KB, 37 views)
Old 26th Sep 2023, 12:34 pm   #7
PaulR
PaulR's Avatar
I bought a cheap basic unregulated 0-300v Griffin High Tension power supply, presumably ex- school as it had a sticky label on it saying it wasn't to be used by pupils(!).
I use it to apply a voltage to the capacitor, adjusting it to keep the current down until it reaches the desired voltage with low current - or doesn't. It has 6.3v sockets and is useful for various things.
Paul
PaulR is offline   Reply With Quote
Old 26th Sep 2023, 10:01 pm   #8
ian_rodger
Here's a thread on one I designed a few years ago an Ardiuno rather than a PIC. Easy build if you are familiar with Arduino programming.
https://www.vintage-radio.net/forum/...d.php?t=144420
ian_rodger is offline   Reply With Quote
Old 27th Sep 2023, 10:51 am   #9
Dazz100
Dazz100's Avatar
I like your design better than the Silicon Chip design.
I already use and know Arduino devices. I have never used PIC before.
Was the second controller to drive the inverter necessary or just easier?
Dazz
Old 27th Sep 2023, 11:08 am   #10
60136 Alcazar
60136 Alcazar's Avatar
I built a capacitor reforming/leakage measuring tester many years ago. I still use it - it's in a metal box labelled "TV Convertor" (band iii to band i) which it does - it will convert any TV from working to non-working in a nanosecond! It uses an EF80 as series regulator and current limiter (max saturation current is around 14mA), and has a built in voltmeter (0-500v) to monitor the voltage at the output terminal. The voltage is turned on at 100v and progressively increased until the capacitor working voltage is reached. For reforming an in-line ammeter displays the current draw and the voltage is increased until the current draw reaches the maximum permissible for the applied voltage and capacitor value; if this is not the capacitor rated voltage, the reforming process is allowed to continue till the current draw (read leakage current) has fallen sufficiently low, and then the applied voltage is increased further, the process repeating till the rated voltage and leakage current are achieved.
Progress consists of doing what you've always done - just more expensively.
60136 Alcazar is offline   Reply With Quote
Old 27th Sep 2023, 12:09 pm   #11
Chrispy57
Hi John,
that sounds interesting - do you have a circuit diagram that you can share?
Chris
Chrispy57 is offline   Reply With Quote
Old 27th Sep 2023, 2:39 pm   #12
ian_rodger
The second controller is not necessary, I was just playing with single chip micros at the time and liked that the Attiny85 could be programmed easily using an Arduino Uno (just 6 wires and a capacitor to connect) and uses a subset of the same commands.
A logic gate base multivibrator with complementary outputs could work just as well. It would need to have an inhibit input that sets both outputs low to avoid unnecessary power dissipation in the drive transistors and transformer, also some frequency adjustment to optimise voltage out from the transformer.
Old 27th Sep 2023, 4:59 pm   #13
60136 Alcazar
Originally Posted by Chrispy57 View Post
Hi John,
Chris
Leave that one with me - after all this time, I'd have to take it apart to find out!!
Old 27th Sep 2023, 5:52 pm   #14
Chrispy57
Hi John,
very kind, but please don't go to all that trouble on my behalf, I was just hoping the diagram would exist and be easily photographed and posted if it was old-school hand drawn.
Chris
Old 27th Sep 2023, 6:22 pm   #15
buggies
buggies's Avatar
Ian - apologies for not returning to your original thread.
I built it with only minor mods - works well and has had a lot use.
Just taken the pic attached.
George
buggies is offline   Reply With Quote
Old 27th Sep 2023, 9:39 pm   #16
60136 Alcazar
Chris
Attached is quick schematic of what's there. This re-used the mains transformer and 16+16/350V smoothing cap from the original TV convertor (dated 1956!). The preset may also be original. All the rest came from the scrapbox.
Name:	TV Convertor Capacitor Leakage Tester-Reformer.jpg
Old 27th Sep 2023, 10:12 pm   #17
60136 Alcazar
..and the mains transformer secondary was 220-0-220 but with bridge rectifier across the full winding.
Old 27th Sep 2023, 10:32 pm   #18
jimmc101
jimmc101's Avatar
Handy for a quick check? 110V-2600V IGBT Voltage Capability Tester
I've checked mine up to 2500v and it seems accurate but with a fair amount of ripple.
Jim
jimmc101 is offline   Reply With Quote
Old 28th Sep 2023, 3:51 am   #19
Dazz100
Dazz100's Avatar
I am thinking direct drive from controller outputs to a pair of self-protecting drive transistors. Implement no-driver-short in software, or alternatively, use a half bridge driver device. The aim to keep the circuit as simple as possible.
Dazz
Old 28th Sep 2023, 4:44 am   #20
Dazz100
Dazz100's Avatar
Hi
I am going to make any further posts on this topic to the thread here:
Capacitor reformer and leakage current indicator
Dazz
