Old 15th Sep 2023, 7:29 am   #1
Blackwood
Default Thorn Automation P5040 - connectors!
Greetings to all from a newbie!
I start by apologising for asking such a stupid question….but could someone confirm the make/type of power connectors this beast of a PSU uses? Better still where I can purchase them, new or used? I have not seen anything like these chassis sockets and I am eager to power this beast up to see if it can be restored.
Thanking you in anticipation.
Blackwood is offline   Reply With Quote
Old 15th Sep 2023, 8:38 am   #2
Cobaltblue
Cobaltblue's Avatar
Default Re: Thorn Automation P5040 - connectors!
Hi and welcome to the forum.
In situations like this a picture is worth a thousand words.
Mike T
Don't care if it was a bargain why's it in my kitchen
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is offline   Reply With Quote
Old 15th Sep 2023, 11:39 am   #3
Blackwood
Thank you, photos to follow when I return home in a day or two…. I was hopeful that someone may know what they were from the model number P5040 to get a head start 😊
Best
Old 15th Sep 2023, 2:07 pm   #4
Cobaltblue
Cobaltblue's Avatar
If this is a PS5040 there was an earlier thread:
https://www.vintage-radio.net/forum/...d.php?t=144933
I snipped a couple of these pictures from the manual linked in the thread above.
Is this the correct item?
Mike T
Name:	Screenshot 2023-09-15 140548.jpg
ID:	285023   Click image for larger version
Name:	Screenshot 2023-09-15 140428.jpg
Mike T BVWS member.
www.cossor.co.uk
Old 15th Sep 2023, 3:06 pm   #5
stevehertz
stevehertz's Avatar
Pilotmariner should know the answer to this one. We both worked at Thorn EMI, I worked in test department and tested just one about 40 years ago, so my recall is zero I'm afraid. I think Mark (pilotmariner) may have commissioned some. Btw, they sold in their thousands to the military and others. Thorn Automation has changed hands a couple of times since then, but I feel the new company will be able to help with a schematic and maybe even a manual. I'll see if I can find out the present name of the company. They've always been pretty good at providing support for earlier products.
There you go: https://www.ultra.group/us/contact/l...ns/uk/rugeley/
stevehertz is offline   Reply With Quote
Old 15th Sep 2023, 3:12 pm   #6
Cobaltblue
Cobaltblue's Avatar
The full handbook is linked to in the thread I linked to earlier:
https://www.flickr.com/photos/13897200@N03/
Of course if its a different unit your suggestion would still be a good lead.
Mike T
Mike T BVWS member.
www.cossor.co.uk
Old 15th Sep 2023, 3:25 pm   #7
stevehertz
stevehertz's Avatar
Mike T
Thanks Mike. They may even have spare parts.
Old 15th Sep 2023, 4:33 pm   #8
Blackwood
Outstanding chaps, thank you. Mike, yes this is the correct picture of the plug and socket that I require. I will reach out and see what is available, thank you again.
Old 16th Sep 2023, 12:03 pm   #9
Chris55000
It might be worth asking Ultra if they can supply a copy of pages 28 and 29 (Firing Pulse Circuit Description) of the PS 5040 Manual, then there'll be everything available for me to republish the content available from the other thread linked in an earlier post in a new book with new drawings, once I've got everything I need, I will make a document with an overall large circuit diagram and interconnection diagram!
(I would like to document all the wiring colours, tagboard layouts, PCB layouts, socket wiring, etc., etc., but at 52 kg, one of these instruments is far too large and heavy for me to handle, so buying one myself in order to reverse–engineer it is out of the question!)
Chris Williams
Old 16th Sep 2023, 6:55 pm   #10
wave solder
wave solder's Avatar
When I tried to obtain documentation some years ago I was told that they didn't have any information available.
wave solder is offline   Reply With Quote
Old 16th Sep 2023, 7:42 pm   #11
Chris55000
I'll keep an eye open – it's even possible my employer might have some – I've been signed off for over two years by my H.R. due to eye–trouble but I might be going back before too long!
Chris Williams
Old 16th Sep 2023, 8:29 pm   #12
Pilot Mariner
Pilot Mariner's Avatar
Location: Burntwood, Staffordshire, UK or Kabaty in Warsaw Poland.
From memory I think the connectors were probably the ubiquitous Plessey pattern 105 or 608 type used on a wide range of equipment at that time.
I remember testing several of these in the early 80s during my period of training at Thorn Automation.
Mark
Pilot Mariner is offline   Reply With Quote
Old 22nd Sep 2023, 1:10 pm   #13
Sean Williams
Sean Williams's Avatar
They are Plessey Mk 7 connectors.
FC Lane may still have some in old stock, but prepare for a shock on pricing!
eBay - search for Clansman power unit connectors, or electronic repair body - these 5050 PSUs were used in that sort of situation.
The connectors turn up from time to time at radio rallies - took me three years to find them for mine.
Sean Williams is offline   Reply With Quote
