Old 7th Sep 2023, 4:36 pm   #3241
millwright2309
Default Re: AVO Multimeter survey
Originally Posted by Superscope View Post
Originally Posted by bobbob! View Post
The sticker on the back states that it was supplied by Universal Instrument Services, Leire, Leicestershire on 13/09/1979,
so I guess that's as good a date as you'll find on one of these! At least, it wasn't made after that...
Dating Multiminors has always been a bit of a problem, and has been a pain for the Survey.
Made even more difficult when it came to light recently that Avo supplied replacement
Mk 5 Movements and Scaleplates for repairs to older Mk's.
Meaning a Multiminor displaying Mk 5 on its Scaleplate is not necessarily a Mk 5 and
other features might be required to actually identify what it is.
One assumes this could also have been the case previously with other Mk's.
Now, very little is cast in Stone with Avo meters as everybody knows, but is it possible that
Universal Instrument Services supplied the Multiminor Second Hand?
The reason I ask, is that it is unlikely (but not impossible of course) the Multiminor was still
being made or supplied in 1979.
The Multiminor was replaced around 1970 by the 70 Series Meters.
It could of course also have been sitting on a Shelf for years and sold as NOS.
Originally Posted by millwright2309 View Post
Hi, universal avometer model 7, number 40632-A-353 with square batteries installed.
Your Meter as you probably know will be a Mk II from 1953.
By square Batteries, I assume you mean the Two 4.5v Cycle Batteries, or do you mean the
single 1.5v Battery?
I am interested in its value and will sell to a collector if anyone in GTA is interested.
As a general rule.
Values of course will depend on it's condition and supplied accessories.
I'm not sure what the values are for Canada, but for the Uk, If its scruffy with chips and
scratches and doesn't work at all, then it has very little value.
You would struggle to get £10 for it here in the Uk for spares.
If it is in very good cosmetic condition with a Case and leads (even with missing Prods) and
it at least shows signs of life, you might be lucky and get around £25-£30.
Although I don't often see Model 7's get that high unless they really are in good shape.
The Model 7 for some reason is not a particularly sort after Avometer and that reflects in the
price.
Some photos would help to gauge general condition.
Ian
It has the square 1.5 volt battery.
millwright2309 is offline   Reply With Quote
Old 7th Sep 2023, 6:08 pm   #3242
The Philpott
The Philpott's Avatar
Avominor Protimeter s/n- 545-558 !
How many do we know of now....would it be 6 including the ghastly steampunked one that featured on etsy some time ago?
I'll start a separate thread with images.
Dave
Old 8th Sep 2023, 9:01 am   #3243
Superscope
Dave
Yes, it is indeed the sixth one we have listed, including the butchered, sorry, Steampunked etsy one.
One assumes this one is probably towards the end of production.
Although we have Six listed, it is not clear if these all actually still survive.
Two of the numbers were provided by Andy Gillham from Avo and I'm not sure if these
were surviving Meters or just happened to appear on historical documentation.
Ian
Superscope is offline   Reply With Quote
Old 9th Sep 2023, 2:48 am   #3244
millwright2309
My model 7 and a Hoyt AC/DC volt meter.
ID:	284712   Click image for larger version
ID:	284713   Click image for larger version
ID:	284714   Click image for larger version
ID:	284715   Click image for larger version
Old 9th Sep 2023, 2:51 am   #3245
millwright2309
The batteries that were in my model 7, bought in August this year 40632-A-353, AC/DC seems to be working well.
ID:	284717   Click image for larger version
Old 9th Sep 2023, 8:47 am   #3246
The Philpott
Wow! I believe that sulphur fumes from the rotting rubber test leads can blacken the switch contacts inside the avo, so best kept separate! Does the AVO 7 have a serial number at the bottom of the scaleplate?
Dave
Old 9th Sep 2023, 4:10 pm   #3247
millwright2309
40632-a-353
Old 9th Sep 2023, 7:21 pm   #3248
bobbob!
AVO Multiminor Mk. 5 : 014205
bobbob! is offline   Reply With Quote
Old 14th Sep 2023, 6:33 pm   #3249
Chrispy57
Avo EM272, part number 5170-425, serial number 175771.
Sadly this faulty unit has been steampunked (sensitively I hope) into a Zener diode tester, as described in a post under the Homebrew Equipment section of the Forum!
Chris
Chrispy57 is offline   Reply With Quote
Old 19th Sep 2023, 2:43 pm   #3250
Nickthedentist
Nickthedentist's Avatar
Just taken possession of:
AVO Model 8, Mk II.
Serial No: 114874-C-1160.
Thanks for letting me have it, Glyn.
Old 21st Oct 2023, 3:45 pm   #3251
WaveyDipole
WaveyDipole's Avatar
Likewise just taken posession of an AVO 8 Mk II, thanks to member Anthony. Search the thread but didn't find it mentioned, so here it is:
Serial number: 821940-C-1158.
The movement seems perfectly fine, but the case is damaged and will require repair, but otherwise looks quite clean.
The battery cover is made of Bakelite rather than the usual black metal plate.
WaveyDipole is offline   Reply With Quote
Old 22nd Oct 2023, 12:47 pm   #3252
The Philpott
-Shortly after this there was a general change from bakelite battery covers to metal ones.
Sometimes it seems like a good idea to use a later cover on an earlier meter- until you find the holes don't quite line up. The difference is so small that i think it was accidental; possibly a slight shift in the setup of the jig.
Dave
Old 22nd Oct 2023, 10:54 pm   #3253
AndyGilham
Hi all, it's been a long time since I've logged in......work and life has taken priority....even over Avometers.
The Avometer collection in Dover continues to grow........all currently stored in a room full to the brim of everything Avo or Evershed.
I recently received a call from a lady who's father was a field sales rep for Avo from 1958 to 1981. Sadly he passed, but had a large collection of meters and documentation. She kindly donated a number of his meters to Megger, so I visited her to pick up 15 meters and approx. 8 boxes full of documents, notes, guides, service manuals.....I still need to sort it all
Andy
AndyGilham is offline   Reply With Quote
Old 24th Oct 2023, 6:39 pm   #3254
Barnmead
Barnmead's Avatar
Welcome back
Good to hear that collection is expanding.
Richard
Barnmead is offline   Reply With Quote
Old 27th Oct 2023, 7:49 am   #3255
AndyGilham
Thank you Richard. I hope you are well.
I am still very annoyed that I was unable to received your collection, it would have really added something special. Unfortunetely it was the wrong time and wrong personal involved to be able to come and collect them. A loss for me and for Megger.
Andy
Old 28th Oct 2023, 8:17 pm   #3256
The Philpott
Hi Andy, nice to hear from you. My Protimeter and Type H Universal Avominor have yet to be attended to, the Type H has a problem with the moving coil carrier binding against the cylindrical 'former' when towards the top end of the scale. Unlikely to be fixable, but we'll see.
Dave
Old 29th Oct 2023, 12:09 pm   #3257
Phil G4SPZ
Phil G4SPZ's Avatar
Dave, you mention the “Type H Universal Avominor”. I have previously commented on the existence of at least four different models of that instrument, in my small collection anyway, but I didn’t know there were official designations. Can you point me towards the relevant information, please?
Many thanks,
Phil
“The place where optimism most flourishes is the lunatic asylum” - Henry Havelock Ellis
Phil G4SPZ is offline   Reply With Quote
Old 29th Oct 2023, 1:38 pm   #3258
The Philpott
Phil, quite apart from the Model 1 meters that went to the military with 'ZD' or 10S/46 references incised and white infilled, (which you've no doubt seen) the Type H Model 1 variant has a special instruction plate denoting it as a Type H.
Richard Allen notes detail differences in the switch assy, but it's basically a Model 1.
(ref- 'Richards Radios')
I'd like to have a closer look at mine but the weather's just turned and it's in the workshop..i know it has the earlier type facia design with finger guards around the terminals.
So...we know we have Type E and Type H variants..perhaps the others never even existed in principle, or just never got off the drawing board.
Dave
Old 29th Oct 2023, 1:58 pm   #3259
Phil G4SPZ
Phil G4SPZ's Avatar
Thanks, Dave. I will run through mine later and check what I’ve got. I vaguely recall that there was a high resistance version of the Minor, and I think I might have one.
Universal Avominors are conveniently small enough to keep in one’s toolbox! I used one in this way for several years till a MultiMinor came along.
Phil
Old 29th Oct 2023, 5:29 pm   #3260
The Philpott
Yes, there is the Model 2 which is 4000 ohm/volt compared to Model 1 400 o/v. Also a Model 1A with a low resistance scale- but electrically identical to a Model 1!
The movement of the Model 2 is noticeably better damped, and i believe that this makes it ever so slightly less accurate than a Model 1; the drag isn't conducive to the pointer always settling at exactly the right spot. (Nit picking really; they're close enough)
If we're talking DC Avominor, there's a 20kohm/volt example which had a limited production run. Curiously the pointer on these is NOT heavily damped; around 4 swings to settle.
Dave
