Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Offered and Wanted Messages > Sets, Parts and Service Information Offered (private sellers only, exact price required, no swaps)
Sets, Parts and Service Information Offered (private sellers only, exact price required, no swaps) You may announce components or sets for sale or offered free here. Private collectors only - no traders. You must include an exact price. No swaps.
Old 9th Oct 2017, 12:22 pm   #21
frankmcvey
Default Re: Lots of 1980s components - sale for charity
More misc items:
Lot 31
Valve Electronic CV7564 Actually a massive, very high power silicon diode capable of handling over 100A specs here. Bear in mind that's a 1cm grid!
Donation 3 + 4 p&p
See Photo 1 below, weight abt 250g
Lot 32
Capacitor Serious kit, presumably from a radar modulator/transmitter. Looks and weighs like a smallish brick. 500pF, Max pulse rating 45KV. Some chipping at corners
See Photo 2 below, weight 2Kg. 3 donation P&P tbd
Lot 33 SOLD
More Attenuators/matching Units 50/75 Ohms coax matching units, plus RF Attenuator
See Photo 3 below, weight abt 300g
Donation 3 + 4 p&p
Lot 34 SOLD
Geared Motor Very nice little motor IP 115V 50 Hz 0.33A. OP abt 2.5W, op shaft speed 1 rpm.
See Photo 4 below, weight abt 300g
Donation 3 + 4 p&p
Lot 35 SOLD
Brandenburg 576B EHT power supply Presumably for a CRT display. I can't find its specs, unfortunately, although the company (AppliedKilovolts) could probably tell you. C/w EHT leads and plugs.
Donation 3 + 4 p&p
See Photo 5 below, weight abt 1Kg
Order by PM only, please.
Frank
ID:	150515   Click image for larger version
ID:	150516   Click image for larger version
ID:	150517   Click image for larger version
ID:	150518   Click image for larger version
frankmcvey is offline
Old 10th Oct 2017, 12:56 pm   #22
frankmcvey
More misc bits; all items 3 donation + 4 p&p, except for lot 38, which will be 3 donation + 2 p&p
Lot 36 SOLD
Relays Two good solid beefy relays. The one on the left is a 4PDT break-before-make with a coil resistance of 2000 ohms. It pulls in at 15VDC.
The one on the right (2PDT) has two electrically separate 150 Ohm coils, either of which will energise the relay at 5VDC. The label states that the coils are balanced, but I don't know what this double balanced coil arrangement achieves; from the contact arrangement it looks as if it may be for latching. I don't know either whether the coils are wound in phase or in opposition.
See Photo 1 below
Lot 37
Circuit Board (NOS) Contains 1 x CV7085 Mullard Germanium PNP power transistor (= OC28)
Qty 6 CV7345 Silicon planar PNP transistors (= BCY31)
Qty 1 CV7421 Zener diode (= Philips BZY95C15)
Plus numerous smaller diodes, zeners and passives.
See photo 2 below
Lot 38 SOLD
Coax connectors
BNC chassis sockets, qty 5
BNC T-piece connectors qty 6
Mini BNC plugs qty 5, chassis sockets qty 3
Unknown coax plugs (look just like a miniature TV aerial cable plug) Qty 3, matching chassis sockets qty 2.
See photo 3 below
Lot 39 SOLD
Another Brandenburg 576 EHT unit Plus cable and plugs. This one contains a working drawing which states the the input takes 12V DC; EHT OP 1 = +1.5KV, EHT OP No 2 = -1.5KV
See Photo 4 below
Lot 40
Calex Power Supply 115V AC input, outputs +/-15VDC @ 200mA
See Photo 5 below
Order by PM, please.
Frank
ID:	150550   Click image for larger version
ID:	150551   Click image for larger version
ID:	150552   Click image for larger version
ID:	150553   Click image for larger version
Old 11th Oct 2017, 8:17 pm   #23
frankmcvey
More misc items:
Lot 41
Hi Power variable resistor Claude Lyons - 2 Ohms, 5A rated
See Photo 1 below
Lot 42
Rotary Switch 250VDC 380AC 16A
See Photo 2 below
Lot 43
Geared Motor This one actually says "Timer" on its packaging. 100-125V 50Hz 2.5W Output shaft 1rpm
See Photo 3 below
Lot 44 SOLD
DC Shunt Motor 24V 3500rpm torque 275 gm/cm
See Photo 4 below
Lot 45
HV fuses Qty 10 off 1.5A @5KV
See Photo 5 below.
Orders by PM, please.
ID:	150613   Click image for larger version
ID:	150614   Click image for larger version
ID:	150615   Click image for larger version
ID:	150616   Click image for larger version
Old 12th Oct 2017, 2:01 pm   #24
frankmcvey
More assorted pieces. All at 3 donation + 4 p&p
Lot 46
Misc Relay 4PDT, 24V. Brass lamp bayonet fitting. Rectangular panel series switch, illuminated button. Reed switch & cable. Very nice 100uA m/c edge meter graduated 0 to 100 in steps of 5.
See Photo 1
Lot 47
Adtech Power Supply IP 115V 50Hz, OP +/- 12V DC
See Photo 2
Lot 48
EHT Test probe Cable has been snipped off, but looks easily replaceable.
See Photo 3
Lot 49
Another Brandenburg 576 EHT unit - these seem to be popular! 12V in, +/-1.5KV out.
See Photo 4
Lot 50
Not entirely sure about this one; it simply says "Equaliser" on the label. The supply listing states "Equaliser Band Stop". I have others similar where the label simply says "Filter". Measuring this one, it gives terminals 1-2 R=48.5K; 2-3 R = 48.3K; 1-3 R=448 Ohms, L=3.2H. No "C" readings, which would seem to imply it's just an L-R filter.
See Photo 5
All orders by PM, please.
ID:	150634   Click image for larger version
ID:	150635   Click image for larger version
ID:	150636   Click image for larger version
ID:	150637   Click image for larger version
Old 18th Oct 2017, 1:01 pm   #25
frankmcvey
Well, all the resistor pack orders have been fulfilled. I picked up the last 3 drums (mainly small resistors and pots) and a large cardboard box (mainly hardware - seals, unions, joints, springs, gaskets etc) on Sunday. Here are some misc lots:
Lot 51 SOLD
Socket Electrical These are very good quality BNC chassis sockets, most still in their primary standard packaging. Qty 10. Donation 2, p&p 1
See Photo 1 below
Lot 52 SOLD
See Photo 1 below
Lot 53 SOLD
See Photo 1 below
Lot 54 SOLD
Another Brandenburg EHT supply - 12VDC in, +/-1.5KV out. Includes cable, plugs and working drawing, still in primary packaging. 3 donation, 4 p&p
See Photo 2 below.
Lot 55
HD Contactor/Relay Coil 115V 50Hz rated 600VAC 2HP. 3 sets of contacts, so can be used for single phase or three phase switching. 3 donation, 4 p&p
See Photo 3 below.
Frank
ID:	150961   Click image for larger version
ID:	150962   Click image for larger version
Old 18th Oct 2017, 2:06 pm   #26
frankmcvey
Some of this stuff is even older than the Type 42 destroyer. Found documents referring to HMS Tiger and HMS Blake.
More misc stuff:
Lot 56 SOLD
Inductor. Various tappings. New, packaging removed for photo. 3 donation, 4 p&p
See photo 1 below
Lot 57 SOLD
Ledex rotary switch P/N 0633-193489 No idea of switching arrangement. New, packaging removed for photo. 3 donation, 4 p&p
See photo 2 below
Lot 58 SOLD
Servo amplifier dtd 1966 Rack mounting. No idea what kit it's from. Contains 3 valves (haven't opened the casing to see what they are)
3 donation, 4 p&p.
See photo 3 below
Lot 59
More coaxial matching units/attenuators. 3 donation, 4 p&p
See photo 4 below
Lot 60 SOLD
Burgess Microswitch Beautiful new HD item. I've seen similar used on aircraft undercarriages. 3 donation, 4 p&p
See photo 5 below
ID:	150979   Click image for larger version
ID:	150980   Click image for larger version
ID:	150981   Click image for larger version
ID:	150982   Click image for larger version
Old 19th Oct 2017, 10:52 am   #27
dave cox
dave cox's Avatar
Lot 51, 52 & 53 look like BNC 50 ohm rather than 75 ohm ?
dc
dave cox is offline
Old 19th Oct 2017, 11:49 am   #28
frankmcvey
Hi, Dave - they certainly look exactly like the input BNCs of my scopes and mate exactly with the 50 ohm test leads I use.
Old 19th Oct 2017, 11:59 am   #29
frankmcvey
Lots 36, 52, 53, 54, 56, 57 and 60 now gone.
Old 19th Oct 2017, 4:55 pm   #30
dave cox
dave cox's Avatar
He who hesitates
Thx for the conformation Frank, now I'll have to wait see if you turn up any more BNC sockets !
dc
dave cox is offline
Old 14th Mar 2018, 1:55 pm   #31
frankmcvey
Hi, All,
Giving this one a bump in case anyone missed it first time round. Have a look through the thread - there's still plenty of stuff left. There are no >1/2W resistors left, other than the large wirewounds, of which there are hundreds.
If you fancy something that has been marked as sold, then by all means ask about it, since there are lots of duplicate items. However, don't ask me to root through 9 barrels and 2 large boxes of stuff to find a specific pot or wirewound, though. Firstly, life's too short. Secondly, in most cases the stuff is still in its primary standard packaging and the label will simply say "Resistor" or whatever, together with its NATO stock number, so the only way you'll really know what is in the packet is to strip off the packaging that has protected it for the last 50 years or so.
Look on it as a cheap lucky dip, and a way to stock up on stuff that might be useful one day.
If there's no further interest in the kit, then I'll pass it on to a retailer of surplus kit for a substantial donation to Sarah's charity, so the stuff will still be available to you, albeit at a somewhat higher price.
Frank
Old 16th Mar 2018, 9:29 pm   #32
Ed_Dinning
Hi Frank, you have a PM/ mail
Ed
Ed_Dinning is offline
Old 19th Mar 2018, 10:12 pm   #33
Ed_Dinning
Hi Frank, have you received my PM's
Ed
Old 19th Mar 2018, 11:24 pm   #34
frankmcvey
Hi, Ed,
Nope, sorry - I don't know why; I've been sending and receiving PMs from others over the last couple of days, and I didn't spot your posts in the thread.
I've just PM'd you with my email address in case it's a problem at your end.
Any ideas, Mods?
Frank
Old 20th Mar 2018, 9:43 am   #35
Ed_Dinning
Hi Frank, over the past months I believe about 4 PM's / mails seem to have gone astray.
I was asking for some of the remaining bits, so I'll repeat via direct email.
Ed
