Old 30th May 2020, 1:04 pm   #41
real0real
Default Re: Watt Torino - Cadetto Repair
with rectifier valve removed voltage from transformer getting a reading of 400v
real0real is offline
Old 30th May 2020, 1:14 pm   #42
ms660
ms660's Avatar
Is that the AC voltage between either of the anode connections and chassis?
Lawrence.
ms660 is offline
Old 30th May 2020, 1:16 pm   #43
real0real
yes from anode connection to chassis 400v
Old 30th May 2020, 1:20 pm   #44
real0real
would this when mean ordering the capacitors make sure there rated at 400v plus ?
Old 30th May 2020, 1:23 pm   #45
Station X
Station X's Avatar
400VAC is the RMS (Root Mean Square) voltage. To convert this to peak voltage you'll need to multiply by the square root of 2, which as I said earlier is approximately 1.41.
Graham. Forum Moderator
Station X is offline
Old 30th May 2020, 1:31 pm   #46
ms660
ms660's Avatar
Note: I wrote the following before I read Grahams post.
Good job you checked that then if that measurement is to be believed.
400*1.414 = 565, that's potentially what the DC voltage across the HT electrolytics can rise to....
See what the others think, seems higher than usual to me even taking into account a field coil loudspeaker if that's what's fitted.
Lawrence.
ms660 is offline
Old 30th May 2020, 1:38 pm   #47
Station X
Station X's Avatar
Looking at pictures of a similar restored set suggests that the speaker is a field coil type.
I'd just fit 600V electrolytic caps and have done with it.
Old 30th May 2020, 1:44 pm   #48
real0real
will have a search for on internet and order 2
Old 30th May 2020, 1:46 pm   #49
Station X
Station X's Avatar
If the circuit is to be believed there are a couple of other electrolytic caps in there.
One is connected to the cathode pin 8 of the 6V6.
The other is connected to the cathode pin 6 of the 6B7
They'll be low voltage types.
If wholesale capacitor replacement is to take place, replace any cap with a value in uF and leave those with a value in pF well alone.
Old 2nd Jun 2020, 1:26 pm   #50
real0real
The 2 600V electrolytic smoothing capacitors have arrived today , proceed to fit and test
Old 2nd Jun 2020, 2:57 pm   #51
real0real
Have just replaced the capacitors, switched on Radio now working OK.
Old 2nd Jun 2020, 3:32 pm   #52
real0real
Many thanks to everyone who as helped , specialy Graham as was bit confused at first as was unable to find a capacitor
Clive
