Old 20th May 2020, 7:35 pm   #21
poppydog
Default Re: Ferranti mains lead
In the pics you can see the red dot on the side of rectifier, this is the output which the wire from that point goes to the + of smoothing cap c25 denoted by brown wire with white tipex dot on the end. Attached to this point on cap is also 1 end of r21, the other end of r21 attached to the + of c24.
poppydog
poppydog is offline
Old 20th May 2020, 8:05 pm   #22
ms660
ms660's Avatar
poppydog
If that's the case and the large component that's connected to the switch is R22 then R22 is in series with R21 and therefore it wouldn't be the same as the schematic, 1k @ 0.034 Amp (your last heater chain current measurement) equals 34 Volts, 34 Volts + 68.3 Volts (that you measured at the input to R22) equals 102.3 Volts which is what you measured at the rectifier.
Lawrence.
ms660 is offline
Old 20th May 2020, 8:34 pm   #23
poppydog
Ok Lawrence thanks for that, will have to try and sort this out tomorrow now.
Regards Poppydog
poppydog is offline
Old 20th May 2020, 10:06 pm   #24
GeoffK
Default Re: Ferranti 925 mains lead
The rectifier + cathode has one end of R21, R22 going to + C25, three connections.
Other end of R21 ONLY goes to C24 + and switch S8 (m = mains)
Other end of R22 goes ONLY TO junction on switch S6 (B = battery) and S7 (M = mains)
The mains battery switch over selector.
Geoff
GeoffK is offline
Old 21st May 2020, 10:59 am   #25
GeoffK
Correction, R22 goes to outside tag on S7. The junction S6,(battery) S7,(Mains) goes to Pin7 (heater) V4 and C22+.
Geoff
GeoffK is offline
Old 21st May 2020, 11:41 am   #26
poppydog
Why is r22 getting so hot as it is at the moment? also something that I've never done before was check to see if r21 is hot and it is, its boiling. Will have a proper look at this later.
poppydog
poppydog is offline
Old 21st May 2020, 11:59 am   #27
GeoffK
Check the resistors with V4 removed, make sure the set is fully discharged by leaving it switched off before removing or refitting any valve. There is a serious short circuit to cause the HT resistor to get hot. Check the output transformer by touching it, is it hot, do not leaving it running for long like this. Check C18 HT smoothing capacitor.
Geoff
GeoffK is offline
Old 21st May 2020, 12:06 pm   #28
ms660
ms660's Avatar
If R22 is passing filament current it will get hot....Isquared*R
If R21 is dropping 34 Volts as previously reported then it will get hot....Vsquared/R
The circuit should be wired/connected as per the schematic.
The brown wire with the white dot from the rectifier's output (as you described) should be connected to the junction of R21&R22&C25, there should be no other connection to that junction, in your photo you can see that the the brown wire with the white dot is connected to the end of R21 that's connected to the mains power supply HT switch S8.
Lawrence.
ms660 is offline
Old 21st May 2020, 3:10 pm   #29
poppydog
So its looking like i have connected 1 end of r22 to the wrong smoothing cap, i will move it and take some more voltages.
poppydog is offline
Old 21st May 2020, 3:35 pm   #30
poppydog
With the end of r22 moved the voltages are as follows
output of rec=90.8v
into r22=90.8v
out of r22=6.01v
pin 7=6.01v
R21 is cold now, r22 is still red hot and the volts on pin 7 are up a bit but not enough.
poppydog
poppydog is offline
Old 21st May 2020, 4:12 pm   #31
ms660
ms660's Avatar
Measure the resistance of R23 and measure the DC voltage across it.
Lawrence.
ms660 is offline
Old 21st May 2020, 4:19 pm   #32
poppydog
This sounds fairly good with the change I have made so far though doesn't it? I also noticed the rectifier is getting fairly warm now, also had a biggish tickle off of rectifier trying to work out just how hot its getting. R22 is very hot, put a wet finger on it and it sizzles. Will look at r23 in a bit.
poppydog
poppydog is offline
Old 21st May 2020, 4:56 pm   #33
poppydog
Lawrence.
R23 out of circuit=53.6r voltage across it= -2.52v
poppydog is offline
Old 21st May 2020, 5:15 pm   #34
ms660
ms660's Avatar
Taking that into account those measurements, the low voltage out of the rectifier would point to the rectifier itself assuming that the reservoir capacitor is of sufficient value, let's see what others think.
Lawrence.
ms660 is offline
Old 21st May 2020, 5:26 pm   #35
poppydog
The capacitance is stated as 32uf but I have got 22uf in there as that was what I had here, has that upset things??
poppydog
poppydog is offline
Old 21st May 2020, 5:50 pm   #36
GeoffK
The grid bias seems about right. There is nearly 4 watts (90.8-6.01=84.79 V/1900=~0.045mA*0.045=0.002*84.79=3.81W) being dissipated by R22 so it will run hot if not sufficient size, but should not be excessively hot. 22uF rectifier smoothing should be just about ok. Check C21 if it is the original 500uF and C22 for leakage that could draw more current through R22, disconnect and fit temporary 100uF 10VDC min if you have spares handy.
Geoff
GeoffK is offline
Old 21st May 2020, 5:54 pm   #37
ms660
ms660's Avatar
Re: Post#35:
Possibly not, but if you do decide to replace the existing rectifier with a silicon rectifier I would fit a 33uF for C25, and the same value for C24.
Lawrence.
ms660 is offline
Old 21st May 2020, 7:54 pm   #38
poppydog
Thanks for all the replies. I will carry out the suggestions mentioned by Geoffk then decide what to do.
I have to decide wether or not to carry on with this as there will almost certainly be a lot more components to buy and I'm unsure what state the valves are in and as I said in a previous post, the radio itself is in very poor shape.
regards poppydog
poppydog is offline
Old 22nd May 2020, 10:41 am   #39
poppydog
Any recommendations what diode/s I could use in place of the old rectifier please?
poppydog
poppydog is offline
Old 22nd May 2020, 12:45 pm   #40
Mike. Watterson
Originally Posted by Herald1360 View Post
TYou should then see about 7.5V at the DL94 pin.
Actually 6.8V is closer to the ideal on mains. The 7.5V is a nominal battery voltage. The filaments are nominally 1.4V parallel, 50mA series, but 1.35V +/- 5% recommended by Philips on mains. The actual series current isn't 50mA due to ballast resistors and significant DL94 anode and screen currents in the filament.
Mike. Watterson is offline
