15th May 2014, 11:29 am | #1 |
Denco coils
Don't know if anyone out there can help with this...
I am trying to finish some radio projects I started many years ago, which are based on Denco coils. I have searched fairly hard to try and purchase the extra bits I need, but can't find exactly what I need....looks like I'll be winding some! The coils I am looking for are the Denco T range. I have found specs for the DP range (and I can even find DP coils to buy) The question is how to the DP coils compare to the T coils? And does anyone have the specs for the T range? |
15th May 2014, 12:03 pm | #2 |
Re: Denco coils
Best iIIIIIII can suggest apart from Googling is put an Advert in the Wanted section.
15th May 2014, 12:47 pm | #3 |
Re: Denco coils
This link - http://markhindes.easywebstore.co.uk...archTerm=denco, shows some T coils for sale.
Leave me alone - I know what I'm doing. BVWS member, EUG, G-QRP Radio Bygones/Radiophile |
15th May 2014, 12:57 pm | #4 |
Re: Denco coils
Some more info here - http://vintageradio.me.uk/info/dencodtb4_data.htm.
15th May 2014, 8:42 pm | #5 |
Re: Denco coils
As I understand the ranges the T (transistor) and DP (dual purpose) are fully interchangeable. The inductance values would (naturally) be identical between the types but the type of wire used may differ (double cotton-covered for higher voltages perhaps?)
Anyway, spec on the ranges can be found here: http://vintageradio.me.uk/info/dencocoils.htm |
16th May 2014, 12:21 pm | #6 |
Re: Denco coils
The transistor range will presumably have low impedance base coupling windings which the valve DP range will lack. The oscillator coils will need quite different coupling windings. The main tuned winding may be identical.
16th May 2014, 6:31 pm | #7 |
Re: Denco coils
Thanks folks. From the links above, I can see that there is a significant difference between DP and T range. I have trawled the web buying some of my missing T range coils, will have to keep a lookout for the rest (or have a go at winding).
BTW the set I am most keen on finishing is a David Gibson superhet.... I am sure it can be made to work, and trying some 38yrs ago, got me hooked on radio - even though it never worked. |
16th May 2014, 7:36 pm | #8 |
Re: Denco coils
See attached if you want to wind your own, and, also: https://www.vintage-radio.net/forum/...d.php?t=106027
Jim |
18th May 2014, 10:37 pm | #9 |
Re: Denco coils
Thanks Jim, this is going to help!
I am trying to make the T range coils, I have the red (2,3,4), blue (4) and yellow (2,4). I am fairly sure the table at the top is the Blue range, and the lower table (oscillator) is the Red range? If I am right, then does anyone know about the Yellow ones? |
