Old 13th Aug 2014, 8:55 am   #21
Ed_Dinning
Default Re: Bottle cutter
Hi Gents, I think paraffin is the recommended lubricant.
Note that there are now "diamond" coated bits available that will probably cut fasted and with less pressure.
Ed
Ed_Dinning is offline
Old 13th Aug 2014, 10:38 am   #22
emeritus
The original Mason Master bit that dad did buy, came with instructions on how to resharpen it. If you examine modern masonry bits, you will note that the tungsten carbide point has a negative rake. I assume they work by crushing the material rather than cutting it. Material is not removed by the leading edge of the point, but by the trailing edge, as it is the trailing edge that is in contact with the material. The narrow trailing edge removes brittle material such as cement or glass by crushing it to fine dust rather than getting under the surface layer and wedging it upwards as with a conventional twist drill. That is why high pressure and slow speed is advised.
emeritus is online now
Old 13th Aug 2014, 12:57 pm   #23
AC/HL
AC/HL's Avatar
Moved to hints & tips, although the original post was a request.
AC/HL is offline
Old 13th Aug 2014, 3:29 pm   #24
maninashed
To drill glass I use a small piece of adhesive tape stuck to the place I want to drill, it stops the drill sliding about and let's you get it started. I use an arrow shaped tile drill. Make a reservoir using putty or something similar, and fill will oil or water. Better to use a pillar drill, steady pressure and medium speed. Works for me.
Bill
maninashed is offline
