Old 14th Apr 2021, 9:55 am   #1
BrionyH
Default Help with 1978 8 Track Player
Hi there,
We have an 8 track player and radio! I was born in 1995 so I've never heard of it before and find it quite fascinating and want to try and get it working properly. We've already bought quite a few tapes for it and it does play and the radio works fine but there's a few issues that mean it's not 100%. Both of us are completely new to any sort of Audio tech but do have experience with computers. It doesn't seem to skip tracks when the button is pressed and it also doesn't play through all the channels. It only plays on the left in the front and right in the back from what we can tell. Does anyone have experience troubleshooting and repairing these players in the UK? We're reasonably open to DIY if that's the only option but would prefer for a professional or someone more knowledgeable o take a look at it. We're in the Stoke on Trent area and willing to travel a reasonable distance. Little worried about posting it incase it gets lost or damaged. We've already worked out it probably needs a belt replacement and the Model is GM2700 and Part no. 7898490. Thank you for any help or replies!
BrionyH is offline
Old 14th Apr 2021, 10:58 am   #2
Cobaltblue
Cobaltblue's Avatar
Default Re: Help with 1978 8 Track Player
There is a pretty comprehensive thread here on some of the 8 track pitfalls.
https://www.vintage-radio.net/forum/...hlight=8+Track
Overall it's a format I quite like and is definitely of its time.
It sounds as if there may be an issue in the tape section if the Radio is OK on all channels.
There are quite a few members in your area but you will probably need to wait a day or two before they see your post.
Mike T
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is offline
Old 14th Apr 2021, 1:44 pm   #3
DMcMahon
DMcMahon's Avatar
Hello Briony and welcome to the Forum.
Is this a Delco in car unit ? (the only 8 track GM2700 I can easily find reference to) or a stand alone unit.
When you say front and back are you referring to front and rear speakers in a car ?
Update - I think it must be a General Motors Delco unit because the part number 7898490 you referenced matches the Delco number.
DMcMahon is offline
Old 14th Apr 2021, 9:19 pm   #4
BrionyH
Hi David! Thanks for the welcome. You are indeed correct. And yeah the car has four speakers. 2 in the rear and 2 in the front. The speakers work fine when using the radio but on the 8 track it only plays out of two. However sometimes it plays out of four, almost like a loose connection somewhere.
BrionyH is offline
Old 16th Apr 2021, 8:19 am   #5
DMcMahon
DMcMahon's Avatar
I am not familiar with car front/rear speaker wiring connections but would have thought that the radio and tape player speaker outputs would be common, I cannot find an electrical schematic for your unit.
First attachment shows the 4 pin connectors for the speaker connections.
Second attachment shows which connector has which connections, if I interpret it correctly, the top connector is for the rear speakers and the middle connector is for the front speakers. Make sure that both of these connectors are fully pushed in.
Name:	Speaker connectors.jpg
ID:	231885   Click image for larger version
Name:	Speaker connections.jpg
DMcMahon is offline
