Old 21st Apr 2015, 3:22 pm   #1
zens.tv
Default 74DD8205B Marantz cass deck schematic/help please
hi all,
this unit has no audio
have replaced leaked caps & check for through hole issues on read/write module,but same results
zens.tv is offline
Old 21st Apr 2015, 5:08 pm   #2
zens.tv
Default Re: 74DD8205B Marantz cass deck schematic/help please
seems that someone has also worked on the head amp PCB and it's in a bit of a state
Name:	haed amp PCB.jpg
zens.tv is offline
Old 22nd Apr 2015, 9:56 am   #3
zens.tv
discovered a broken print track line,on head amp module
suspect it's due to the previous engineers handy work
zens.tv is offline
Old 22nd Apr 2015, 12:34 pm   #4
crudmeister
It would appear someone has gone in to replace SMD electrolytics with through hole types, probably due to the SMD's going bad - quite commonplace to find this now in 1980's/1990's as they seem to be failing in troops due to age.
Hope you got it fixed - if not, please let us know and you may get answers / help here.
All the best
Rob
crudmeister is offline
Old 22nd Apr 2015, 3:58 pm   #5
zens.tv
hi Rob,yes all working now.
to be honest,i always use minature through hole types.
don't trust those smd electrolytics.
zens.tv is offline
