Old 18th Jan 2016, 3:25 pm   #21
ramblers37
Default Re: Vintage TV Help!!! 1958 Bang & Olufsen
Question! My RF modulator is for PAL tv system, wouldn´t that make it incorrect for a 1958 danish tv?
ramblers37 is offline
Old 18th Jan 2016, 4:02 pm   #22
dragonser
dragonser's Avatar
that is a very nice television receiver you have.
From looking at the instructions that come with the modulator... it is possible to change the output spacing of the sound and vision signals . This is so the modulator is compatible with different countries. It would be worth checking which output spacing has been selected. 4.5 mhz is used in mostly the Usa
the uk uses 6.0 mhz
I don't actually know what standard would be required for a Danish Tv, but I would try the 5.5 mhz sound vision spacing.
Another point which I don't yet know the answer to, if you change the sound vision spacing, has the modulator been made so that it also changes the channel allocation ? As I think different countries use different channel frequencies.
I do have a dragonsat modulator here that does cover VHF as well as UHF, and also does the different sound vision spacings .
regards Peter B
dragonser is offline
Old 18th Jan 2016, 4:08 pm   #23
PAL is a colour television system.
What we need to know is what TV broadcasting frequencies were used in Denmark in 1958 and the number of lines the picture had.
Station X is offline
Old 18th Jan 2016, 4:52 pm   #24
SteveCG
My understanding is that Denmark used the System B TV standard from the outset, so the sound vision spacing should be 5.5 MHz. I reckon that a set from that era would only cover the VHF TV bands.
SteveCG is offline
Old 18th Jan 2016, 6:43 pm   #25
ramblers37
Yes that i also belive to be true. system B
Old 18th Jan 2016, 6:48 pm   #26
ramblers37
I have a friend that doesn´t have any mechanical understanding, no matter how much or simple I explain things. Today I think I know how he feels
Channel allocation? sound vision spacing? I do not know! he he. But I do recall having read that system B uses 5.5 MHz
Old 18th Jan 2016, 6:54 pm   #27
kan_turk
kan_turk's Avatar
I can confirm that Denmark used system 'B' - 7MHz channel spacing with sound carrier at 5.5MHz - VHF channels 2 - 4 in band 1 and channels 5 - 12 in band 3 (later when additional spectrum was required UHF channels 21 - 68 were employed using system 'G' (a variant of 'B') when colour arrived it was indeed PAL and used the existing channels
kan_turk is offline
Old 18th Jan 2016, 7:07 pm   #28
ramblers37
So was does this mean? i need a modulator where I can set the channel spacing and also the sound carrier? is the channel spacing perhaps the same now as back then?
Questions from an ignorent! sorry
Old 18th Jan 2016, 7:37 pm   #29
dragonser
dragonser's Avatar
sorry for not making my post clearer. according to the yellow page you have shown, the modulator you can be switched for several different Tv systems, and 5.5 mhz is one of the options. you would need to hold down the channel up and channel down buttons for three seconds, then the display changes from the channel number to show the sound vision spacing. then you could check it is set to 5.5 . then power the modulator off and then back on again.
if it were me I would try setting the television to one of the channels where you get snow, and then changing the lower channel selected on the modulator and see if you get a picture and sound. I mean the channels 13 or below.
does the television work on fm radio ?
regards Peter B
Old 19th Jan 2016, 1:40 am   #30
kan_turk
kan_turk's Avatar
Hi - I would disregard the sound spacing for the present - it has no relevance until you get a picture - set channel to '2' by pressing button on modulator until '02' appears on readout and set TV channel selector to '2' only valid channels are 2 - 12 (there is no ch 1 or 13) use fine tuning knob (concentric with channel selector) to peak signal
kan_turk is offline
Old 19th Jan 2016, 4:16 pm   #31
peter_sol
Sound spacing is for FM sound surely this set will be AM for the TV sound.
peter_sol is offline
Old 19th Jan 2016, 5:30 pm   #32
Nuvistor
Nuvistor's Avatar
System B, which we think this set is would be FM at 5.5Mhz offset from the vision carrier.
https://en.m.wikipedia.org/wiki/Broa...vision_systems
Frank
Nuvistor is offline
Old 19th Jan 2016, 8:04 pm   #33
kan_turk
kan_turk's Avatar
I think considerable confusion has been introduced to this thread by a misunderstanding of western European TV standards and an attempt, however well meaning, to superimpose British 405 line parameters on the current issue - system 'B' used in most of western Europe including Denmark (7MHz channel spacing, neg vis modulation, FM sound spaced 5.5MHz from vision carrier - ch No.s 2 t- 4. 5 - 12) - the modulator described in post #1 is compatible with system 'B' - sorry to be so blunt but I feel that misinformation is impairing assistance to the OP - kindest regards to all, John
kan_turk is offline
Old 19th Jan 2016, 11:39 pm   #34
German Dalek
German Dalek's Avatar
I am just entering the discussion a little late, I own the same set.
Please contact a very good friend of mine from the Radiomuseum Ringsted (Bjarne).
You can get there all kind of help.
http://www.radiomuseum.dk/
Good luck,
German Dalek
And now something completly different:
MARC BOLAN, he was/is the real king of Pop Music!
German Dalek is offline
Old 21st Jan 2016, 10:22 am   #35
Heatercathodeshort
Heatercathodeshort's Avatar
A very interesting receiver. It has a look similar to our PYE V2 12" model from 1952/3. John.
Heatercathodeshort is offline
Old 24th Jan 2016, 9:31 pm   #36
ramblers37
So what is your conclusion? Should it work? I have tried channel four and five on the modulater and searched on all the channels on the tv. Is my setup correct? Good antenna signal into the mpeg4 box, SCART to the modulater, rf cable to the tv?
Old 25th Jan 2016, 2:30 am   #37
kan_turk
kan_turk's Avatar
Hi - I had bowed out of the discussion as I thought you had got assistance nearer to home but yes it should work - I would set the modulator and TV both to the same channel (I suggest only try ch 2 - 4 for a start as these are in the same band) a close-up pic of the channel selector on the TV would be useful - best of luck
kan_turk is offline
Old 25th Jan 2016, 2:26 pm   #38
Nuvistor
Nuvistor's Avatar
Re post 11, Have you tried Julie's suggestion of feeding the modulator to a more modern known working analogue TV.
Once you get the modulator etc proved good you can then try it on the vintage TV.
Frank
Nuvistor is offline
Old 25th Jan 2016, 11:08 pm   #39
ramblers37
Yes i did that and it works fine.
I tried the fm radio in the set and it doesn´t work, so for now I thank you all for your help. The Bang and Olufsen is going to the mechanic
Hopefully it returns in good working order
I will post it as soon as there is any news.
Thank you all!!
Ole Skov, Denmark
Old 25th Jan 2016, 11:15 pm   #40
Nuvistor
Nuvistor's Avatar
Look forward to the news it is all working and some photos.
Frank
Nuvistor is offline
