27th May 2020, 1:15 pm | #161 |
Re: Superstar 6900N V6 - Fault with SSB mode
Hi
This is the PSU I am using, it has one advantage, there is no noise on the output that I can detect, and it is well protected for over current. It has 2 separate outputs of 12 & 14 amps which I have strapped together. I have tested it up to 30 amps, but it will shut down if it detects a short. We never did suss out how adjust it to set the OP volts. There are two trimmers but they set the output current limit for each supply. see here, http://www.golbornevintageradio.co.u...d.php?tid=7616 OK here are a few images Mike Last edited by crackle; 27th May 2020 at 1:25 pm. |
27th May 2020, 1:21 pm | #162 |
As I'm not a member of that forum I was unfortunately not able to view the images, but it is obviously a SMPSU - you're quite lucky it does not generate RF interference, most do to a certain extent.
Edit: I see you added some images in your previous. Very neat build in that new enclosure. Last edited by SiriusHardware; 27th May 2020 at 1:34 pm. |
27th May 2020, 3:39 pm | #163 | |
73 John |
