6th Jun 2018, 6:37 pm | #1 |
Pye SSB200 HF mobile
Hello everyone.
Has anyone got any spare crystals they want to sell for a PYE SSB200. Crystal calculation is freqency + 10.7. Anything for 80m , 40, 20m would be ok. I picked up the PYE SB200 HF set 4 channel at Stockwood park rally. Just want a crystal to test the rig. Question anyone else played with these rigs ? |
7th Jun 2018, 7:34 am | #2 |
Re: Pye SSB200 HF mobile
What crystal can type is it Andy? I would guess HC6/U.
I'll have a look in my rock collection. Are you interested in rocks for 5MHz as well? 73 Roger/G3VKM |
7th Jun 2018, 1:03 pm | #3 |
7th Jun 2018, 1:44 pm | #4 |
Andy,
I have a bag of about 25 HC6/U crystals on 14.4083MHz, which should bring you out on 3.7083MHz. Let me know if you'd like one. 73 Roger/G3VKM |
7th Jun 2018, 2:32 pm | #5 |
Sorry should have said HC25 type crystals.
Any HC25 crystals considered including 5 mhz. |
7th Jun 2018, 2:37 pm | #6 |
Hi Roger
Yes please.How much for one. My landline is Removed by moderator Last edited by Station X; 7th Jun 2018 at 3:33 pm. Reason: Telephone number removed. Use the PM system. |
7th Jun 2018, 6:07 pm | #7 |
Haven't seen one of those in ages. Knew I should have gone to Stockwood Park.
I might have beaten you to it These probably want a VFO based on an Si570 or similar. I did that to a Southcom SC130 for 60m which I call the rusty box (It is that, I built the case at the Arbury Road training centre as a Home Office Project and never painted it - loong time ago). It was originally top band but 60m came along and more interesting at the time. Last edited by Jon_G4MDC; 7th Jun 2018 at 6:12 pm. Reason: sp! 0/10 |
8th Jun 2018, 6:41 am | #8 | |
73 Roger/G3VKM |
10th Jun 2018, 9:19 am | #9 |
As Jon has said, a synthesiser would be worth considering - at least while you're evaluating the radio. For this kind of thing, I find one of those cheap Chinese si5351 boards combined with a Bus Pirate and a PC to be invaluable. Stick those two on a breadboard and you can have any frequency between about 8KHz and 200MHz with a few keystrokes.
73 G0JLR |
10th Jun 2018, 9:34 am | #10 |
If Andy already has a variable-frequency RF signal generator available, might it be possible to inject a test signal from that?
10th Jun 2018, 9:41 am | #11 |
I don't see why not. I've done this many times but I'm usually fiddling with VHF stuff and my signal generator is not really stable enough. The si5351 is as stable as a crystal.
10th Jun 2018, 9:59 am | #12 |
Agreed, I was just trying to think of ways that Andy could do some basic tests without any initial outlay on parts. A synthesised sig-gen could be used to better effect, obviously.
14th Jun 2018, 8:36 am | #13 |
OK. just a quick update.
Crystal arrived from Roger G3VKM. Connected up a few meters of cable for a antenna. Pye making the right sounds.I even put a carrier from my antenna analyser. Receiving signals OK. It appears the microphone has not been wired correctly. So this will be the next job. Then to check out power output through a power meter and dummy load. More news to follow. Andy G6OHM |
14th Jun 2018, 1:18 pm | #14 |
PM sent if you want a "radio check"
73 Fred G4BWP |
14th Jun 2018, 8:25 pm | #15 |
Ditto, I'm not too far away in Norfolk.
73 Roger/G3VKM |
13th Aug 2018, 6:34 pm | #16 |
Hi all not done much with the Pye SSB200. Been busy doing a Bathroom refit.
Have down loaded the manual. Nowhere in the manual is the microphone socket pinout. Have checked through the manual 3 times now. Can anyone help with pinout so I can wire a microphone? Andy G6OHM |
14th Aug 2018, 11:24 am | #17 |
Hello Andy, doesn't it use the same DIN style connector with locking ring as used on M(X) 294/3 and W15 back into history? I thought so.
I would be amazed if one of those mics did not work, especially the non electret ones. |
14th Aug 2018, 7:21 pm | #18 |
Hi John
Thanks for the info.Will look in the Chris Lorek PMR books. Many thanks Andy G6OHM |
14th Aug 2018, 7:53 pm | #19 |
looking at the solder side of the 5 pin lockable din plug. Starting at 7 o'clock, clockwise to 9, 12, 3 and 5 approx. 7 O'clock pin 1, 5 O'clock pin 5.
STANDARD Pye mic connections for this were (Pin # first) 1 Mic live 2 mic earth (screen) 3 ptt 4 Earpiece audio live (earpiece earth same as mic earth) 5 ptt I wish i had a £ for every plug I replaced! I did see that rig at DD car boot, was tempted as it was very cheap, but I have enough already! SSB130 with mains psu and the rare SSB170, Europa lookalike! Rob
Apprehension creeping like a tube train up your spine - Cymbaline. Film More soundtrack - Pink Floyd |
