Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Other Discussions > Forum Announcements and Comments
Forum Announcements and Comments Announcements about forum changes will be made in this section. All new threads here now require moderator approval.
Reply
Old 2nd Jun 2025, 4:14 pm   #2241
DMcMahon
DMcMahon's Avatar
Default Re: The Thanks Thread
Thanks to yestertech (Andy) for the R2R drive belts that safely arrived recently.
DMcMahon is offline   Reply With Quote
Old 2nd Jun 2025, 6:46 pm   #2242
HamishBoxer
HamishBoxer's Avatar
Thank you JackRae for BT Hub, very grateful.
HamishBoxer is offline   Reply With Quote
Old 4th Jun 2025, 7:25 am   #2243
defender
Thanks to Keith (KeithsTV) for the projector and bulbs, I'll be looking at my 8mm films now.
Thanks,
Jonathan
defender is offline   Reply With Quote
Old 11th Jun 2025, 3:36 pm   #2244
ScottBouch
ScottBouch's Avatar
Massive thanks go to G6ONEDave for sending me some lamps.
These will help to simulate the EE Lightning aircraft warming system 'Attention Getter' flashing lamps. These lamp units are not the right type, but are close enough for a practical demonstration to the public.
Cheers, Scott
www.scottbouch.com
ScottBouch is offline   Reply With Quote
Old 26th Jun 2025, 3:21 pm   #2245
DMcMahon
DMcMahon's Avatar
Thankyou to Jolly 7 for the Grundig TN12 power adaptor that safely arrived today, it was very well packaged.
Old 3rd Jul 2025, 5:54 pm   #2246
Station X
Station X's Avatar
One post moved to a new thread here:-
https://www.vintage-radio.net/forum/showthread.php?t=220799
Graham. Forum Moderator
Station X is offline   Reply With Quote
Old 4th Jul 2025, 6:21 pm   #2247
Julesomega
Julesomega's Avatar
My thanks to Nigel Vinylspinner and to Ken Ambientnoise for the offers of the Powersafer automatic power switch and the polystyrene capacitors, for which Nigel kindly arranged the transport. Now I'm looking forward to evaluating the power switch
- Julian
It's good here
Julesomega is offline   Reply With Quote
Old 8th Jul 2025, 6:30 am   #2248
ajs37
ajs37's Avatar
Many thanks to Ken (Ambientnoise) for the Bush TR82B - I'm looking forward to restoring it!
Andy
ajs37 is offline   Reply With Quote
Old 21st Jul 2025, 8:07 am   #2249
vinylspinner
Thanks to Christopher, high-vacuum-house, for the Denon CD player that I collected from RWB. Cleaned, serviced and running perfectly.
Also many thanks to Ken (Ambientnoise) for the Avo 8, working nicely.
Thanks guys.
vinylspinner is offline   Reply With Quote
Old 23rd Jul 2025, 9:52 am   #2250
turretslug
turretslug's Avatar
Thanks to Nigel vinylspinner for a splendid assortment of many polystyrene capacitors- I'm sure that I'm in common with quite a few here in being grateful for his taking on the task of dividing up a vast number of these components, parcelling them up and sending them out to people on the forum,
Colin
turretslug is offline   Reply With Quote
Old 23rd Jul 2025, 11:41 am   #2251
Stockden
Thanks to Nigel vinylspinner from me too. I'm particularly grateful because I needed the capacitors to be posted, which probably tripled the amount of work involved.
Hugh
Stockden is offline   Reply With Quote
Old 23rd Jul 2025, 12:27 pm   #2252
m0cemdave
Thanks to Nigel (vinylspinner) for the massive amount of work he has done in sorting, packing and posting all those poly caps for the benefit of forum members. Mine arrived today, a most useful selection.
m0cemdave is offline   Reply With Quote
Old 23rd Jul 2025, 1:03 pm   #2253
radioman
radioman's Avatar
I would also like to thank Nigel (vinylspinner) for the big box of capacitors that I received yesterday and think he should get a medal for the huge amount of time & effort he's spent distributing these to fellow forum members.
Andy
G-QRP #12697
radioman is offline   Reply With Quote
Old 23rd Jul 2025, 5:51 pm   #2254
qualityten
I also want to thank Nigel (vinylspinner) for the huge box of poly caps received today. Beautifully labeled, packaged and posted. Much appreciated!
qualityten is offline   Reply With Quote
Old 25th Jul 2025, 8:31 am   #2255
Vintage Engr
Another huge vote of thanks to Nigel, (Vynilspinner) for the polystyrene capacitors.
Thanks for the immense amount of work you've put in to make these available to members. & saving them from the 'electronic waste-tip' where they could so easily have ended up!
I second the medal award!
David.
Vintage Engr is offline   Reply With Quote
Old 28th Jul 2025, 11:06 am   #2256
bc312
bc312's Avatar
Yes, huge thanks to Nigel for the work and time to sort, pack and distribute these capacitors. Also a shout out to VT Fuse (Mike) who took on the original task and request the help to sort and distribute. Great job chaps.
Mike
Leave me alone - I know what I'm doing.
BVWS member, EUG, G-QRP
Radio Bygones/Radiophile
bc312 is offline   Reply With Quote
Old 30th Jul 2025, 10:38 pm   #2257
Reelman
Reelman's Avatar
A special thank-you to Craig Sawyers for the Class D Wavemeter that arrived safely this week. A fitting companion to my 19 sets. Been after one for some time so thanks Craig!
Peter
Reelman is offline   Reply With Quote
Old 31st Jul 2025, 6:17 am   #2258
MIKEG4IIA
Many thanks to Ed Dinning for the valves. Well packaged. Only one duff one so all is good.
MIKEG4IIA is offline   Reply With Quote
Old 2nd Aug 2025, 8:35 am   #2259
ScottBouch
ScottBouch's Avatar
Massive thanks to Nigel (vinyspinner) for the awesome selection of capacitors sent! All organised into marked bags, it must have taken him ages to sort out!
A real philanthropic gesture, massive thanks!
Cheers, Scott
www.scottbouch.com
Old 9th Aug 2025, 12:19 pm   #2260
petertheorgan
petertheorgan's Avatar
Massive thanks to Jeremy ( Pamphonica) for the knob bright
the kindness of most of the people on this form is wonderful !
Thanks again
Peter
petertheorgan is offline   Reply With Quote
Reply
Copyright ©2000 - 2026, vBulletin Solutions, Inc.
Copyright ©2002 - 2026, Paul Stenning.
