14th May 2007, 9:52 pm | #1 |
Foster-Seely FM Discriminators
I'm the proud owner of a Pye FenManII A beautiful set which puts my Bush VHF64 somewhat in the shade performance-wise. It is not yet fully restored and much still needs to be done.
I'm chasing a strange problem in the FM discriminator (see other post) and I see the Pye uses a Foster-Seely type whilst most contemporary sets use a Ratio Detector. Why did Pye go its own way here and not use the more common Ratio Detector? Is there some performance advantage? I cannot find a satisfactory answer in any of my text books. Put me out of my misery please
Jim G4MEZ |
14th May 2007, 10:21 pm | #2 |
Re: Foster-Seely FM Discriminators
As I understand it the Foster-Seely detector has a better performance than the ratio detector from a linearity point of view. Or put another way it produces less distortion. It's dis-advantage is that it requires a limiter stage before it to get rid of all the AM that may be on the carrier.
The ratio detector is not sensitive to AM on the carrier and so for general use is preferred, No doubt Pye were happy to go to the expense of an extra limiting IF stage and use the better detector for this up market set. I use a Fenman II as a daily use set and very nice it is too. |
14th May 2007, 10:33 pm | #3 |
My understanding goes like this:
Unlike the Ratio Detector (R.D.), the Foster-Seeley (F.S.) is not self-limiting with regard to amplitude changes in its input. Therefore, with a F.S., a stage of amplitude-limiting is necessary, prior to the detector. The F.S. produces less distortion than the R.D. (F.S. up to 1% compared to 3% for the R.D., both for a 75 kHz deviation). The F.S. produces approx. twice as much output signal compared to the R.D. The R.D produces an AGC voltage which can (and should) be used to control the gain of amplifying stages prior to the detector. It can also be used as a tuning indicator. This voltage is not available from the F.S. Generally, the R.D. is cheaper to implement than the F.S. in a given design. That's probably the main reason why it was almost universally used in FM broadcast receivers (although these days, PLL's are the method often used). Furthermore, I believe that the R.D. was derived from the F.S. - but I may be wrong on this Al / Skywave. |
15th May 2007, 10:10 am | #4 |
I don't agree here. Foster Seely tuned circuits are used in the discriminator and in the ratio. There is a limiter arrangement called "dynamic limiter". The ratio is a clever combination of both dynamic limiter and discriminator. Thus if you want to compare them, you must campare a discriminator with dynamic limiter added to a ratio. There is no reason why one of these should give more or less distortion. To use the ratio arrangement you needed a licence (from RCA?). That is all. Kind regards, Darius |
15th May 2007, 12:14 pm | #5 | |
(Regulars on here will know of my bias in favour of these excellent sets!) Regards,
Brian |
15th May 2007, 8:40 pm | #6 | |
I'm pretty sure you are right about that Al. I have been looking through my books for a definitive answer because I am sure I've read it quite recently but I haven't been able to find the text. One interesting bit of information that I did find was in Chas Miller's book Valve Radio & Audio Repair Handbook, and was this. The Foster Seeley Discriminator was invented by D.E.Foster and S.W.Seeley in 1936 and the subject of a paper read to the Institute of Radio Engineers in March 1938. This of course predates its use as an FM detector in domestic receivers. Chas's book describes its use in generating the error voltage in AFC systems. |
16th May 2007, 1:30 am | #7 | |
(a) "Electronic Communications Systems", 2nd. Ed., by George Kennedy (McGraw Hill), 11th. printing 1983; (b) "Radio & Television Engineers' Reference Book", Editor J.P. Hawker (aka G3VA), 4th. Ed., 1963. Various ARRL handbooks (and other USA-origin reference books) and assorted publications of the RSGB do make some useful references, but of course these are tailored to AmRad use of FM = NBFM in the AmRad world. Unfortunately, my copy of "Langford" makes no reference to FM - probably because it's a very old issue. (Ditto "Foundations", MGS). However, I am reliably informed that improved forms of discriminator are referred to by Langford in a 1960 publication and Sturley in 1965. Al / Skywave |
17th May 2007, 3:12 pm | #8 | |
The earliest FM Detector was developed back in the 1920's and was called the Travis Frequency convertor which is explained in the book to some detail before moving on to the Phase Discriminator and then the Ratio Detector. Apparently the development of FM dates back to the early 1920's.
Simon BVWS member |
17th May 2007, 5:55 pm | #9 |
Hello,
Don't all FM radio receivers (and 6MHz intercarrier sound in TVs) use a limiter, prior to the FM demodulator - of whatever type? The limiter is incorporated in the final IF amp stage of a radio (AM/FM or FM only sets), but with bias adjusted to clip the IF signal - on FM only. I'm pretty sure that a practical method of Frequency Modulation - for radio - was developed/invented by Mr Edwin Armstrong (USA) in 1933. Edwin Armstrong received U.S. patent 1,342,885 for a "Method of Receiving High-Frequency Oscillations Radio" for his FM technology. He also invented regeneration (1913) and superheterodyning (1910s). Just "google" for more information! Regards, Dazzlevision |
30th May 2007, 11:49 pm | #10 | |
Apparently, it all arose accidentally and quite spontaneously whilst he was doing some experimental work with "ordinary" regenerative receivers. Occaisionally, various stations could be received that with their known ERP and distance, couldn't readily be accounted for with the cct. he was using. The fact that the effect seemed to "come and go" at random made an investigation of the cause difficult to pin down - to put it mildly. It was only several months later - and after a lot of work - that the "penny dropped" - and the super-regenerative receiver was born. Al / Skywave |
