9th Feb 2016, 6:47 pm | #1 |
Garrard SP25 MK3.
Hi, I have started a service on my old SP25/3 and taken off the turntable. The next is the main gear cam, but it will not shift off the shaft. The circlip has been removed and I do not want to use too much force. Is it likely to be the hard grease issue?
David Last edited by AC/HL; 9th Feb 2016 at 9:46 pm. Reason: Thread split |
9th Feb 2016, 9:51 pm | #2 |
Re: Garrard SP25 MK3.
Hello and welcome.
Yes it is! Use some WD40 and heat from a hairdryer. Don't force things or you'll loosen the post which the cam rotates on. N. |
9th Feb 2016, 11:55 pm | #3 |
I usually heat the cam with a powerful hairdryer then when its really hot gently lever it up with two flat bladed screwdrivers under the cam.
Do not force anything, keep heating until it does come off. |
12th Feb 2016, 10:36 pm | #4 |
Thanks Chaps, just the advice I needed.
David. |
