Old 13th Feb 2016, 8:45 am   #21
Edward Huggins
Default Re: Garrard SP25 Mk 3 Cartridge
If you research the playing of 78s, you will find that there are different stylus tips depending which period of recordings you prefer. Post war 78s, such as the good quality Decca FFRR type, should play well on the G800. Pye/Nixa also made Vinyl 78s with a low surface noise. Edward
Edward Huggins is offline
Old 13th Feb 2016, 10:38 am   #22
ben
ben's Avatar
At91 = at3600
Regards,
Ben.
ben is offline
Old 13th Feb 2016, 11:32 am   #23
Edward Huggins
If you are playing post-war 78s - typically the very good Decca ffrr series - then the Goldring G800 78 stylus would be ideal. It will need a suitable tracking weight and of course the groove modulation of a 78 will load the pre-amplifier more. However, if you are going to play pre-war electrical or acoustically recorded shellac, I would take advice as to the optimum stylus tip size. Edward
Old 13th Feb 2016, 12:07 pm   #24
Growlerman
Growlerman's Avatar
I have the AT91 installed in my Dual 1226 and for a cheap magnetic cartridge it sounds very good. Richer sounds were doing these for about £12 when I got mine late last year. I believe you can get a 78 rpm for this cartridge.
I've never been a fan of G800/820 cartridges so I wouldn't spend a lot of money on a replacement stylus. I also wouldn't spend a lot of money on a cartridge for that deck certainly not something like an Ortofon 2m red.
Growlerman is offline
