17th Aug 2021, 7:52 pm | #1 |
ICOM R7100 receiver
Hi peeps. I had a R7100 given to me yesterday......Duff, No output on any band except the Highest, where there is nothing to hear anyway
While I was surveying it.. "Tinkering" I noticed a 10.7 Mhz I.F output on the back panel. Using my scope I could monitor input signals.. so the fault was past that stage. Using my FRG7 as a tunable I.F I connected, as you do, to the R7100, and smoke started to eminate from the R7100. Power off smartish Looking at the circuit... ICOM in their wisdom have 9V DC fed via a rf choke to the output jack. Obviously a DC block cap was fitted and the FRG7 was indeed very useful, showing the receiver worked to that point. After a nights rest, I delved deeper and found the 3rd Mixer L/O oscillator had no output. The 10.245 Mhz xtal was duff. With a 11.155 fitted the receiver is back working .. I have put a request in the Wanted column for a xtal. Why that DC output is configured like that ?? Anyone any idea ??
Should get out more. Regards Wendy G8BZY Last edited by Wendymott; 17th Aug 2021 at 8:15 pm. Reason: Typo |
17th Aug 2021, 10:19 pm | #2 | |
Re: ICOM R7100 receiver
Wendymott wrote:
Great receiver, you'll love it BUT the power supply runs very hot on the 7000 - your 7100 may be different. I run mine on an external 12volt linear power supply.
Cheers - Martin ZL2MC Last edited by majoconz; 17th Aug 2021 at 10:31 pm. |
17th Aug 2021, 11:46 pm | #3 |
Hi Martin. Thanks for the info... so really it is dual purpose In / Out...I have cut the track and inserted a 10 nF in series...Job done
Its not intended as a receiver as such... just an.. as and when radio.. much as the FRG7... been in the cupboard till last night.
Should get out more. Regards Wendy G8BZY |
18th Aug 2021, 12:22 am | #4 |
Hi Wendy - you didn't really need to add another cap if you snip the inductor - there's lots of small caps in the way.....
Cheers - Martin
Cheers - Martin ZL2MC |
