Old 18th May 2020, 12:08 pm   #1
Mr Etronic
Default Y63 "Magic Eye"
Hi. has anyone seen a y63 "magic eye" failed? Mine is not green but I can see a faint orange light on my Etronic RA640
Mr Etronic is offline
Old 18th May 2020, 1:11 pm   #2
music-centre
Default Re: Y63 "Magic Eye"
They "always" seem to be failed in my experience, the magic eyes, especially early ones, don't last anything like as long as the other valves. The glow you can see would be just the heater, worth checking the supplies to it against the manual though , of course.
Welcome to the forum.
Steve.
music-centre is offline
Old 18th May 2020, 1:39 pm   #3
paulsherwin
paulsherwin's Avatar
As Steve says, all the magic eyes with metal targets don't last long. Owners would rarely bother having them replaced because of the cost and the fact that the radios work perfectly well without them. Practically every radio with a magic eye restored in the last 30 years has needed it replacing, which is why NOS magic eyes are scarce and expensive now.
paulsherwin is offline
Old 18th May 2020, 6:48 pm   #4
Sideband
Sideband's Avatar
Check the high value resistors feeding the target and anode....one or both may have gone high. Replacing them may result in the eye reverting from nothing to barely visible in a dark (and I mean DARK) room!!
On Spike Milligan's headstone......I told you I was ill...
Sideband is offline
Old 18th May 2020, 7:32 pm   #5
ValvoStef
ValvoStef's Avatar
I had this in my KB set, I thought the magic eye was gone, replaced it (a mere 10 quid on ebay) still the same. I checked the power supply and the anode voltage was down to 50V. To my surprise, the radio was working OK, apart from the magic eye. It turned out that the rectifier valve was duff, once replaced, the magic eye was working again. Worth checking this first, I nearly threw away a good Y63.
Failing to prepare is preparing to fail ...
ValvoStef is offline
Old 18th May 2020, 9:12 pm   #6
cathoderay57
Unless you are prepared to lose your money, IMHO it isn't worth the gamble of buying untested magic eyes from auction sites. I've even seen images of examples stated as "tested working" showing the orange heater glow mentioned in Post #1 with not a trace of green. Also seen a spate of other valve types advertised as "selling on continuity" which is not quite as bad assuming the vendor doesn't have a valve tester. Then of course there is the "new old stock" or "opened unused" unfortunately of which a proportion will be "pulls" shoved back in the box after a new replacement was fitted. It's an imperfect world of course so buyer beware and are you feeling lucky! In fairness to sellers I have to say for all the valves I have bought that tested u/s I have asked for and received a refund. Cheers, Jerry
cathoderay57 is offline
Old 18th May 2020, 9:14 pm   #7
ekjdm14
If it is indeed dead, after checking the supply voltages, and the OP wishes to restore normal operation. Is there a Russian equivalent to the Y63?
I know there are new ones available equivalent to later "eyes" such as the EM83 etc but not sure if they make anything that'd suit these earlier valves. It is possible to get lucky with untested valves, but generally I read "untested" as "tested and was dead". Again though, the sellers I've dealt with have been reasonable with any problems.
ekjdm14 is offline
Old 19th May 2020, 10:03 am   #8
bluepilot
Could you replace it with an LED replacement? Search Ebay for something like "OEIL MAGIQUE ELECTRONIQUE" (You might need Google translate for the description)
Stuart
bluepilot is offline
Old 19th May 2020, 10:14 am   #9
Cobaltblue
Cobaltblue's Avatar
I think a few people have used Russian Magic Eyes like these:
https://www.ebay.co.uk/itm/1pcs-x-6E...wAAOSw--9eOr2v
No recommendation not dealt with this seller however there are many people selling these valves.
Mike T
Don't care if it was a bargain why's it in my kitchen
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is offline
Old 19th May 2020, 11:44 am   #10
Or closer to home.....
https://www.vintage-radio.net/forum/...ad.php?t=97804
Herald1360 is offline
Old 19th May 2020, 12:38 pm   #11
Chris55000
Hi!
The Russian 6E5S works fine but you need a base wiring change!
Y63:–
1:– i.c. 2:– h 3:– a/d 4:– t 5:– g, 6:– n.p. 7:– h 8:– k, g'
6E5s:–
1:– i.c., 2:– h, 3:– a/d, 4:– i.c., 5:– g, 6:– t, 7:– h, 8:– k, g'.
Both types Vh 6.3V 0.3A, Vt 250V, Ra 1M, Vg –22V zero shadow angle.
To rewire a Y63 socket for a 6E5S transfer the lead and the end of the (usually 1M) anode resistor formerly connected to pin 4 to pin 6.
Chris Williams
Chris55000 is offline
Old 20th May 2020, 2:47 pm   #12
jhalphen
Hi to all,
@Mr Etronic : re : Magic Eye replacement module.
i posted this a while ago....
The LED indicator module described below is sold completely assembled and replicates an eye tube tuning indicator (round type, EM-34,...) with startling accuracy.
As a bonus, you can chose an array of colours instead of the traditional green.
If you desire so, the module can also indicate the tuning frequency and the IF offset is selectable.
Disclaimer : i have no relationship to the vendor, aside of having purchased a few for myself.
Best Regards
Jhalphen
https://www.radioelec.com/oeil-magiq...4_384-834.html
jhalphen is offline
Old 23rd May 2020, 8:59 am   #13
Mr Etronic
I am tempted to get one of these to try and keep a working valve eye for nostalgia.....can I ask how it looked when working, were you pleased with the effect?
Old 23rd May 2020, 9:03 am   #14
Mr Etronic
Thanks for all the replies. I'll check voltages first then I'll replace with a like magic eye. I want to keep it as was for as long as possible.
Old 1st Jul 2020, 12:36 am   #15
Mr Etronic
Finally got round to it. On the Y63 I put a voltmeter over the anode (pin 3) to chassis and got 42V. So I will try the same.
Old 1st Jul 2020, 1:14 am   #16
Mr Etronic
Mind you the rectifier 5z4g is brightly lit.
Old 1st Jul 2020, 10:23 am   #17
Mr Etronic
THIS is anode resistor is giving 1.18 megaohms.
Old 1st Jul 2020, 11:53 am   #18
HamishBoxer
HamishBoxer's Avatar
At 20% tolerance,if I am correct,it is not miles out. (1M)
G8JET BVWS Member and V.M.A.R.S
HamishBoxer is offline
Old 1st Jul 2020, 12:01 pm   #19
ColinTheAmpMan1
ColinTheAmpMan1's Avatar
The fact that the rectifier filament is glowing isn't indicative that the rectifier is working as it should. The emission could be down or there could even be internal connections that are broken, etc. Best to check the DC voltage on the cathode and, if you have a scope, the ripple there, too.
Colin.
ColinTheAmpMan1 is offline
Old 1st Jul 2020, 2:52 pm   #20
Mr Etronic
I take it that will be the rectifier by the transformer on the right...in which case someone spotted it might not be a 5z4g which has a different shape.
