26th Nov 2019, 10:20 pm | #41 | ||
Re: Dansette Conquest Auto
Lawrence. |
27th Nov 2019, 1:33 pm | #43 |
Some good initial readings for the Pentode section of the ECL82:-
Pin 6 (Anode) : 248V Pin 2 (Cathode) : 10V Not so good news for the Triode section but I'll have to sort out R6 first - this should be 220kΩ but now out of circuit is reading 2.61MΩ !!!"
BVWS Member Last edited by Station X; 27th Nov 2019 at 9:46 pm. Reason: At OP's request. |
27th Nov 2019, 2:04 pm | #44 |
The voltage between pin 2 and pin 3 should be approx. the same as the cathode voltage, the voltage between pin 2 and chassis should be approx. 10 volts if all's well.
Lawrence. |
27th Nov 2019, 2:41 pm | #45 | |
Meantime I've attached my first attempt at a cleaned up version of the Conquest Auto MKII schematic - a big thanks once again to Lawrence. I've re-labelled all the text where I can and tidied up some of the graphic symbols - those associated with the valve and transformers are still a bit rough! I've also removed the "rogue 56V" label as discussed above. Any feedback welcomed.
BVWS Member |
28th Nov 2019, 10:54 am | #46 |
I've now replaced R6 with a new 220kΩ resistor and went back and measured the valve pin voltages.
Pentode section of the ECL82:-Removed the valve and checked that I had 0.00V on Pin 3 - I think this implies that there is no leakage (?) from the audio coupling capacitor (C4) which is a mustard cap. So no need to replace?? Hopefully looking much better - still have a couple of resistors to replace.
BVWS Member Last edited by DonaldStott; 28th Nov 2019 at 11:13 am. |
28th Nov 2019, 12:37 pm | #47 |
Looking good.
I don't generally check the cathode to grid voltage where auto-bias (cathode resistor) is used.. Measuring from chassis to grid should show 0V or very slightly positive. Not more than about 0.1V. You'll soon know if you have a leaky coupling cap, as the voltage will be way higher than this.
28th Nov 2019, 1:21 pm | #48 |
Thanks Graham - both Pin 1 (Triode Control Grid) to chassis and Pin 3 (Pentode Control Grid) to chassis are measuring 0.00V.
Still only getting 0.86V across that blue electrolytic - a bit low but probably passable?? Replaced all out of tolerance resistors and squirted inside Volume and Tone controls with De-Oxit - no more scratchiness. Now for that Dansette hum ... I know there are two main culprits: - 1. The smoothing and reservoir capacitors in that big can - comprises C5 (32μF), C6 (25μF) and C7 (32μF) - expensive to replace! (Cricklewood do a 32μF + 32μF 500V Dual Electrolytic Can Capacitor for £7.80 and a 22μF 450V Radial 105 deg Capacitor for £1.14 although a much lower voltage component would seem fine in this location2. The wires/connectors associated with the external sockets at the rear of the case. Any other possible causes??
BVWS Member Last edited by DonaldStott; 28th Nov 2019 at 1:35 pm. |
28th Nov 2019, 1:28 pm | #49 |
This simple circuit can still work for years (sub-optimally) with many components badly out of tolerance, so you seem to have had a real struggle with this one.
The other causes of hum can be the routing of the PU screened cable from the tag on the underside of the BSR autochanger to the volume control and the mains carrying lead to the turntable motor. If you do replace the 3 caps in the large can, this will also include the ECL82 pentode cathode cap. Replacing that can often have a beneficial effect on the volume level.
Edward. |
28th Nov 2019, 3:08 pm | #50 |
You need to get used to the causes of hum.
As a general rule if it's regardless of volume control setting it's the smoothing, but if it increases with volume setting, then it's likely to be wiring placement etc. |
28th Nov 2019, 4:07 pm | #51 | ||
I suppose I could look at additional screening in some way for the mains carrying lead and other similar cables or look at re-routing them? I replaced these 3 caps in my previous Dansette Monarch restoration but this didn't impact on the hum to any significant degree?
BVWS Member |
28th Nov 2019, 4:50 pm | #52 |
I would not leave these long trailing leads in situ as they can still induce hum whether connected to the rear sockets or not. It is highly unlikey that you will ever use these, so they can be removed....BUT do remember that the LH and RH cartridge channels will need to be bridged and the speakers correctly wired in parallel as they will no longer be connected by those switched sockets at the rear. If the hum is still present at nil volume, then the 3in1 can should be replaced - you can use seperate components.
Edward. |
29th Nov 2019, 11:11 am | #53 | |
This is the tag on the underside of the BSR autochanger (a bit blurry, sorry): - So the plan is to re-use the screened cable that runs from the volume control and disconnect that at the rear socket - this would be re-connected directly to the underside tag (black and red wires). The other grey and white cables would be disconnected from the underside tag and rear sockets? The wiring and connections at the rear sockets are a bit confusing (to me!) but don't you just love the Dansette craftsmanship: - I think I've worked out what all the cables and wires do apart form the orange wire that runs from the Primary on the Output Transformer to the L.S. rear socket?? As for the connecting the loudspeakers in parallel, this seems fairly straightforward? This picture clearly shows the yellow and black twisted pair that come from the Secondary on the Output Transformer along with the red and black twisted pair that come from the rear sockets. A blue wire connects one set of tags across the speakers. I'm assuming it's just a case of disconnecting the red and black twisted pair and connecting another length of wire between the two other tags on the speakers. Of course all the other changes detailed above would have to be undertaken first. Has anyone else carried out these modifications and with any degree of success??
BVWS Member Last edited by DonaldStott; 29th Nov 2019 at 11:13 am. Reason: Typo |
29th Nov 2019, 11:42 am | #54 | |
https://www.radiomuseum.org/r/danset...uest_auto.html Lawrence. Last edited by ms660; 29th Nov 2019 at 12:03 pm. Reason: added link |
29th Nov 2019, 12:01 pm | #55 |
Looking at your pictures, the wiring is the same as in a Conquest Auto Mk1 I repaired a couple of months ago, and the orange wire does indeed go from the secondary of the o/p Transformer to the extension speaker socket switch, so the two speakers can simply be wired in parallel at the speaker terminals, and the orange wire discarded. Unfortunately I didn't take any pictures of the player I repaired, which has been back with it's owner for several weeks now, but the modifications are straightforward. However, I presume you realise that you need to wire the two channels of the cartridge in parallel at the tagstrip to obtain proper mono reproduction. (Apologies if I'm stating the obvious) B.T.W., what is/was the difference between the Conquest Auto Mk1 & Mk2? Reading this thread, they appear to be electronically the same thing, and very similar in appearance, too.
29th Nov 2019, 12:06 pm | #57 |
As I noted in post # 55, yes, as long as you wire the two speakers in parallel.
29th Nov 2019, 1:06 pm | #58 | ||
Where I am confused is the way in which I have the black and red wires running from the cartridge to the tag strip but I also have the yellow and blue wires connected to the tag strip but not connected at the cartridge which, obviously in this case, only has two terminals.
And even more confusing for novices like myself, the grey co-axial cable that runs from the TAPE socket at the rear to the Volume control doesn't have it's shield connected at the rear socket. Quote:
https://elektrotanya.com/dansette_pr...wnload.html#dl In Post #45 above I attached my first attempt at a cleaned up version of the Conquest Auto MKII schematic. Hope this helps?
BVWS Member Last edited by DonaldStott; 29th Nov 2019 at 1:34 pm. |
29th Nov 2019, 1:07 pm | #59 |
To be clear, to rewire the speakers leaving the Ext L.S socket in place but disconnected, the wiring needs to be like the R.H. pic below.
Apologies for the manky scan of the circuit.
29th Nov 2019, 1:35 pm | #60 |
Thanks David - clarity as usual, much appreciated !
BVWS Member |
