Reply
Old 16th May 2024, 8:53 am   #1
Josep1955
Default Collaro Conquest Made in Brazil. Mains voltage?
It may seem incredible but I have managed to find a Collaro Conquest Made in Brazil record changer, I think from 1959, completely new, unreleased. Can anyone tell me what the voltage of these Collaro made in Brazil was? Or they are prepared for 110 and 220 volts?
Regards.
ID:	297633   Click image for larger version
ID:	297634   Click image for larger version
ID:	297635   Click image for larger version
ID:	297636   Click image for larger version
Josep1955 is offline   Reply With Quote
Old 16th May 2024, 10:47 am   #2
Analogue man
Default Re: Collaro Conquest Made in Brazil. Mains voltage?
what superb condition! There was a plate rivetted to the motor on the British built ones which gave voltage.
Graham
Analogue man is offline   Reply With Quote
Old 16th May 2024, 12:18 pm   #3
Edward Huggins
Amazing. This is a very late model Conquest with the, so-called, "Transcription" tone arm which had adjustable tracking weight. It looks as if some kind of non-UK cartridge has been added. I am not aware of any Collaro (or Magnavox who took an interest in Collaro at this time) licensing agreement to build these overseas?
Edward.
Edward Huggins is online now   Reply With Quote
Old 16th May 2024, 1:36 pm   #4
Josep1955
It is manufactured in Brazil or was to exported to the Portuguese and Brazilian market. The box and instructions are in Portuguese. But in Brazil, the voltages of 110 and 220 volts coexist, so my question.
Old 16th May 2024, 1:54 pm   #5
Sideband
Sideband's Avatar
According to my list of world voltages,Brazil will be 120V/220 60Hz. I suspect that the 220V is for high power items like washing machines, tumble dryers, cookers and heaters etc. I believe a similar arrangement is used in the US.
The biggest problem for running the record changer will be the 60Hz pulley fitted which will cause it to run slow on the 50Hz mains that we and the continent use. You might have to change the motor unless you can find a 50Hz pulley.....and be able to change it!
Sideband is offline   Reply With Quote
Old 16th May 2024, 2:03 pm   #6
Hartley118
Hartley118's Avatar
Originally Posted by Josep1955 View Post
Regards.
An interesting find! If it’s been made for the Brazil market, it’s likely to have both 220V and 127V mains taps because both voltages are used, depending on region. The one mains constant is frequency, which is the 60Hz US standard. So the turntable would run pretty slow on the European 50Hz frequency and would need either a replacement pulley or drive motor specified for 50Hz.
Edit: posts crossed. Just my addition to the flood of information!
Martin
BVWS Member
Hartley118 is offline   Reply With Quote
Old 16th May 2024, 4:45 pm   #7
Chiltern
Collaro pulleys are usually one of the easy to remove. simply twist the pulley with the spring (which gives the drive) and pull it off. There is even a tiny hole drilled thro the end to prevent air/hydraulic lock. The fan/collar stays in position. Collaro pulleys were available in a range of sizes to give small adjustment for speed, denoted by colour.
Alan
ID:	297659   Click image for larger version
Chiltern is offline   Reply With Quote
Old 16th May 2024, 11:52 pm   #8
ben
ben's Avatar
I have seen those red Collaros here in Madrid and on wallapop, so they are out there, if you needed a European motor for yours.
Regards,
Ben.
ben is offline   Reply With Quote
Old 17th May 2024, 10:25 am   #9
Chiltern
Pictured the coils on a UK 200/250v motor. coils in series. Given the different voltages in Brazil I would have expected a changover connector like on a Garrard of that vintage.
Some investigation of the coil wiring first before looking for another motor.
Alan
Old 17th May 2024, 8:08 pm   #10
Ed_Dinning
If a Brazilian motor is fitted it may be easiest to fit a UK/European motor, which will then be the correct volts and frequency
Ed
Ed_Dinning is offline   Reply With Quote
Old 18th May 2024, 12:11 pm   #11
Maarten
Was it made in Brazil for the Portuguese market or was it made in Portugal? It's not clear from your posts that it actually mentions Made in Brazil?
In any case, you could have a look as to how the motor is wired (series or parallel). Also be aware that any capacitors might be electrically leaky and/or go ****! once voltage is applied.
Maarten is offline   Reply With Quote
Old 18th May 2024, 3:29 pm   #12
Josep1955
From happy to sad in 1 minute. The box with the Collaro has arrived this morning with a strong blow and the spindle broken. I returned it to the seller.
It is assembled in Brazil with English components and adaptations for the Brazilian market (60 hertz, capsule and needle). It does not correspond to the explanations received that the seller's father-in-law made furniture to embed the Collaro, it is not compatible with the Spanish electricity network 50 hertz.
I don't know how the Collaro has arrived in Spain, because it is not used for Portugal either. Well, unfortunately isn't my problem anymore, end of history.
Thank you very much for your contributions and comments.
Josep
ID:	297712   Click image for larger version
ID:	297713   Click image for larger version
ID:	297714   Click image for larger version
ID:	297715   Click image for larger version
Old 18th May 2024, 6:44 pm   #13
Sideband
Sideband's Avatar
Probably would have been easy to source a new spindle. They are not rare.
Old 19th May 2024, 11:41 am   #14
hayerjoe
Oh dear, such a shame, it survived 60 years in pristine condition and then got damaged by clumsy/careless postal workers. I was enjoying this thread ??
hayerjoe is offline   Reply With Quote
Old 19th May 2024, 11:45 am   #15
Station X
Station X's Avatar
Or inadequate packing.
Graham. Forum Moderator
Station X is offline   Reply With Quote
Old 19th May 2024, 11:49 am   #16
hayerjoe
ah yes, that was probably it. still a shame
Old 21st May 2024, 2:21 pm   #17
Josep1955
Default Remove the spindle from a Collaro Conquest
Good morning,
Has anyone ever pulled the spindle out of a Collaro Conquest? Pressure-mounted or with screws like the Garrard record changer?
Thank you very much!
Old 21st May 2024, 2:57 pm   #18
Station X
Station X's Avatar
Default Re: Remove the spindle from a Collaro Conquest
I thought you'd returned this to the sender?
https://www.vintage-radio.net/forum/showpost.php?p=1638680&postcount=12
Old 21st May 2024, 3:23 pm   #19
Josep1955
True, everything was ready for the return. The seller, who had the Collaro in a storage room for 30 years, has made me an offer that I cannot reject, returning a large part of the paid. Now, I'm going to try to change the spindle, and, with an electricist friend, we'll try to solve the 60-hertz frequency.
Old 21st May 2024, 5:10 pm   #20
Chiltern
Default Remove spindle from a collaro
Here are pictures of a Spindle showing the screw fixing should the info still be required..
Alan
ID:	297854   Click image for larger version
ID:	297855   Click image for larger version
Reply
