Old 29th May 2020, 8:07 pm   #1
Serthish
Default Pre-BD1 Sugden-Connoisseur Deck identification please.
Hello all,
Just looking for some info on the below deck that I was kindly gifted by a local member on here.
Prepare yourselves, it's in a bad way. And that's an understatement!
All I can make out is that it has a LEAK arm and is a Connoisseur manufactured by A.R. Sugden and Co Ltd.
Many thanks in advance.
ID:	207152   Click image for larger version
ID:	207153   Click image for larger version
Serthish is offline
Old 29th May 2020, 8:29 pm   #2
ajgriff
ajgriff's Avatar
Default Re: Pre-BD1 Sugden-Connoisseur Deck identification please.
I think it's the remains of one of these (see attached photo). Not sure whether or not it actually had a model number.
Alan
ajgriff is offline
Old 29th May 2020, 8:40 pm   #3
Ted Kendall
I think this was just known as the Three Speed - idler driven, and very good in its time. This was part of a decent mono setup once - the arm is for the Leak moving coil mono pickup (a stereo version was announced but never appeared because Leak sold out to Rank) and there is also the rather fine Auriol pickup control. Worth some time and trouble. A careful clean is first on the agenda, methinks...
Ted Kendall is offline
Old 29th May 2020, 10:03 pm   #4
Serthish
Thanks for your responses gents. Unfortunately I don't have the time or knowledge to refurb so I'd rather leave any and all cleaning etc to someone else who knows what they are doing.
A bit of further research has thrown up a couple more questions however.
A lot of the pictures and threads I can find on the 3 speed have the Connoisseur label writing on a diagonal whereas mine is flat. There also appears to be a difference in the knob at the bottom left of the deck, others I've seen have had more switch type knobs. Is it likely that this has been modified? Or a early/later version?
Appreciate that it is a lovely piece of audio history, and once fully restored, could make someone very happy again. Believe it or not, this and 2 Thorens were salvaged by a friend from the tip one day!
Edit: Additional further research suggests that its a Connoisseur Type B 3 speed turntable - https://www.beykirch.net/Thorens/Thorensbuch_k.pdf page 155
Serthish is offline
