8th Nov 2017, 10:08 am | #1 |
Philips Reverbeo F8X15A/60. Value?
Hello!
I am new to this forum, and would like to ask for your kind help in the following. I have come across this Philips Reverbeo F8X15A/60 (pictures included). As I understand it was made in the 1960's, is still in working order and in pretty good shape. There is little or none information on this type of Philips sets on the internet. I would be extremely grateful for your opinion and estimates of this piece. The current owner is asking around 450 pounds for it - is it a good price or an overcharge? Thank you in advance for your input! |
8th Nov 2017, 11:58 am | #2 |
Re: Philips Reverbeo F8X15A/60. Value?
Well this is a quite rare piece. They also made a table model radio only version.
That price is certainly high. I would go listen to it on all its wavebands and check that the autochanger fully works. These are NOT EASY to repair. You should also check the Reverb function as well. If all works I would offer up to £200, no more. The owner is unlikely to get £450. If you buy cheaper on the basis that it needs some repair work, do take into account this is quite a complex unit and even a very reasonably priced repair might well be anything from £50 upwards.
Edward. |
8th Nov 2017, 1:43 pm | #3 |
Please note that this is a 60Hz export model, so the record player will run slow so if you want to play records you'll have to modify or replace it. I think the official way is to mount another pulley on the motor. I would say 100 pounds is reasonable, but if you really like it you can pay more.
The table model radio of which the chassis was used, is probably the B7X14A. I don't know the type of the record changer but service manuals and other information can be found. |
8th Nov 2017, 1:43 pm | #4 |
Hi Edward,
Thank you for your advice! Maarten, thank you as well. |
