10th May 2019, 6:51 pm | #1 |
Levell TM1 transistor tester
More tidying up and came across a manual for the Levell TM1 transistor tester.
Doesn't seem to be around so made a copy. My scanner no longer works, too old for the software or something, so photographed it and converted to pdf using the print function. Now have 12 pages, each about 5.5MB. I can't see how to merge them into one file, or work out how to do a size reduction. Any offers? I will need an email address by pm so I can send the pdf files. Might be worth saving them on BAMA or somewhere? |
11th May 2019, 3:56 am | #2 |
Re: Levell TM1 transistor tester
PDFSAM will let you merge them into one file.
There's a thread on here somewhere with various other options. As for size reduction, what format did you convert from to PDF? If you used JPG, you may get a better size by converting those first to TIFF or PNG and then to PDF. |
11th May 2019, 9:08 pm | #3 |
PM sent
John |
30th May 2019, 6:53 pm | #4 |
Delays delays, apologies.
What I hadn't realised was that I had a TM12 transistor tester, not a TM1, and another one by Advance that I thought was the TM1. Had an offer from John to scan the TM1, which seems the easiest option. PM sent. Has anyone got page 6 for the TM12 please? I downloaded a copy from an old thread here but got two page 3's. |
1st Jun 2019, 3:43 pm | #5 |
Here's the scan. Pity there's no parts list!
Paper copy is ready to post back. John |
2nd Jun 2019, 10:28 am | #6 |
Thanks John.
