Old 11th Sep 2019, 4:54 pm   #21
TonyDuell
Default Re: Alternative EHT system for HMV 902.
As of course do laser printers (I assume modern ones do, certainly the 'classic' ones I've worked on do). Laser printers and photocopiers have many similarities...
I seem to remember the voltage is a few kV and probably not enough for the EHT on a TV CRT.
TonyDuell is online now
Old 11th Sep 2019, 6:37 pm   #22
FERNSEH
FERNSEH's Avatar
Good evening everyone,
Many thanks for all your ideas, we've now have many solutions to the problem of producing EHT for our old TVs. All will be given consideration.
The power unit is now removed from the HMV 902. The power pack you see in the attachment was made for the set by the late Gerry Welles in 1988. The original unit was completely rusted away because it had been buried in the garden of the house where the set was found.
The Majestic transformer is mounted on an adaptor plate because the transformer Gerry had fitted was Parmeko drop through oil filled type.
So later today it will be removed from the power chassis and refitted in the 901.
DFWB.
FERNSEH is offline
Old 11th Sep 2019, 8:01 pm   #23
beery
beery's Avatar
Mmm, we like an adaptor plate
beery is offline
Old 11th Sep 2019, 8:52 pm   #24
FERNSEH
FERNSEH's Avatar
"Mmm, we like an adaptor plate2
Hi Andy,
nothing to do with vintage TV but these guys are great exponents of adaptor plates and brackets.
https://www.youtube.com/watch?v=SUeytYlxW7c
DFWB.
FERNSEH is offline
Old 11th Sep 2019, 9:12 pm   #25
They've taken on an even bigger project.... just so they can make bigger brackets!
Radio Wrangler is offline
Old 11th Sep 2019, 10:27 pm   #26
Argus25
No Longer a Member
I just looked and the transformer type I posted are still available. The advantage of the split bobbin is that you can take off the primary and alter that to any mains voltage you like +/-heater winding and you will never have any trouble with the sealed secondary, its a real gem. They are an ideal donor for vintage TV repairs, that is if there is the space. just remember to open the air gap.I just used a file and lacquered the filed edges.
https://www.ebay.com/itm/3500v-Core-...0AAOSwGvhUGaYe
As I recall too they ran a very low flux density, nowhere near saturation, so probably you could get the peak voltage up higher too , or use a doubler.
Argus25 is offline
Old 12th Sep 2019, 8:47 am   #27
Jac
Jac's Avatar
A nice transformer Hugo.
Indeed we need a higher output voltage (if the U16 rectifier tube is to remain in circuit): c. 4000 VAC.
Well, the primary would need to be changed anyway.
David, just out of curiosity, how high is the resistance of the EHT winding of your Majestic Transformer Co transformer?
Jac
Sorry, forgot to include the U16 characteristics graph.
Name:	U16 characteristics.jpg
Jac is offline
Old 12th Sep 2019, 12:18 pm   #28
FERNSEH
FERNSEH's Avatar
"David, just out of curiosity, how high is the resistance of the EHT winding of your Majestic Transformer Co transformer?"
Hello Jac,
The resistance of the EHT winding is 7.23Kohms and the primary is 25.7ohms. Primary is wound for 230volt mains.
The laminations stack dimensions are: 115 X 95 X 45mm.
DFWB.
FERNSEH is offline
Old 12th Sep 2019, 1:08 pm   #29
Jac
Jac's Avatar
Thank you David.
Jac
Jac is offline
Old 12th Sep 2019, 11:12 pm   #30
FERNSEH
FERNSEH's Avatar
It's oot! All twenty-seven inches of it. Now I can start work on the power unit.
DFWB.
FERNSEH is offline
Old 16th Sep 2019, 10:26 am   #31
llama
llama's Avatar
The complete chassis from a 5" telly (50p from a car boot) could go in a box to provide EHT.
Graham
llama is offline
Old 16th Sep 2019, 12:09 pm   #32
FERNSEH
FERNSEH's Avatar
Graham
Hi Graham,
Using the 5" TV chassis wouldn't be a permanent solution but can be considered a safe source of EHT during servicing sessions.
Will be doing the transformer swop in the HMV 901 later today.
DFWB.
FERNSEH is offline
Old 16th Sep 2019, 3:51 pm   #33
FERNSEH
FERNSEH's Avatar
Old transformer oozes goo. EHT went down to 2KV and then the fuses blew.
DFWB.
ID:	190293   Click image for larger version
FERNSEH is offline
Old 16th Sep 2019, 5:05 pm   #34
FERNSEH
FERNSEH's Avatar
The attachment shows how the Majestic transformer is fitted in the Marconi 702. No adaptor plate was needed.
DFWB.
FERNSEH is offline
Old 16th Sep 2019, 5:11 pm   #35
Jac
Jac's Avatar
A truly beautiful transformer David!
It looks very well made.
The 3.5 kV output may avoid a lot of problems of the 4 kV original transformer. A good choice, I think.
For the relatively thin CRT phosphor-layer, the difference in light-output will be small, while benefiting from a somewhat more generous deflection because of the somewhat lower EHT.
Jac
Jac is offline
Old 16th Sep 2019, 9:24 pm   #36
FERNSEH
FERNSEH's Avatar
Hello Jac,
Because of the light load a 3.5KV transformer should produce a rectified output of just under 5KV DC.
I'm considering asking the Majestic Transformer Company for a quote for two more EHT transformers.
The new transformer required spacer washers because the screws that secure the smoothing choke protrude through the chassis.
DFWB.
ID:	190303   Click image for larger version
FERNSEH is offline
Old 16th Sep 2019, 9:36 pm   #37
peter_scott
peter_scott's Avatar
It fits very well.
Peter
peter_scott is offline
Old 17th Sep 2019, 9:55 am   #38
FERNSEH
FERNSEH's Avatar
Hi Peter,
Extra holes had to be drilled into the transformer end plates so that it can be fitted on the existing fixing points. It's much better practise to modify replacement parts rather than attempt to do any alterations to an eighty year old chassis.
DFWB.
FERNSEH is offline
Old 17th Sep 2019, 4:28 pm   #39
FERNSEH
FERNSEH's Avatar
Transformer is now fully wired into the circuit but before the power unit is reinstalled into the base of the cabinet a few tests must be carried out to confirm all is well with this heavy chassis. The attachment shows the EHT bleeder chain, one resistor has been found to have gone high value, that component will be replaced.
Got to get this thing right because I don't wish to be lifting the CRT out from the cabinet and refitting it too often.
DFWB.
FERNSEH is offline
Old 17th Sep 2019, 5:56 pm   #40
FERNSEH
FERNSEH's Avatar
Showing the sound receiver in the HMV 901. Valve line-up is: X41, VMP4G, MHD4 and N41. IF is 1.5Mc/s.
DFWB.
FERNSEH is offline
