23rd Dec 2011, 10:37 pm | #21 |
Re: Stereo valve amp not working.
This just came to me.
When I use my amplifier, I always listen with it to the television or my computer. And I play the sound trough a headset which is connected to the amplifier with a jack-input with decoupling (or how you say it in English) function to turn the speakers off and activate the headset. Could this usage make my valve's wear faster? And what is the average life span of a valve? |
23rd Dec 2011, 10:37 pm | #22 |
If valve #2 does not overheat in other sockets, this suggests a problem with the bias voltage on socket #2. Check the voltage on pin 5 of all sockets.
Are the other valves OK in socket #2?
23rd Dec 2011, 10:39 pm | #23 |
Yes, they are "ok". They just light up a bit brighter, so the valve in that socket gets more power.
I will measure it. |
23rd Dec 2011, 10:41 pm | #24 |
438V and on the other valve socket 1 439V
23rd Dec 2011, 10:44 pm | #25 |
If you have 439V on pin 5, which is the control grid, you have serious problems. The voltage here should be negative.
23rd Dec 2011, 10:46 pm | #26 |
Ow, sorry wrong pin.
On every valve socket, pin 5 has a stable -38VDC |
23rd Dec 2011, 10:51 pm | #27 | |
If that is the case I'd say that valve #2 is very sensitive to variations in bias voltage, which must be lower on valve socket #2. EDIT. We crossed in the post. If what I say above is true it must be due to something over than bias voltage.
23rd Dec 2011, 10:54 pm | #28 |
So to recap
pin voltages: 3# 433 VDC 4# 433 VDC 5# -36 VDC (on socket #1, 3, 4 -37 VDC 8# 0V (the same on socket #1, 3, 4) |
23rd Dec 2011, 10:57 pm | #29 | |
It would be useful to have a full set of readings for all the output valves.
23rd Dec 2011, 10:58 pm | #30 |
yes, only that valve (valve #2) is overheating, and yes only in valve socket #2.
And like I said earlier, if you put another valve in socket 2 it works perfectly (not tested with sound) but it "shines" a little brighter than the other valves… So what could the error be? The valve is too sensitive? EDIT: Do I need to measure also the little valve's or only the E34L's? |
23rd Dec 2011, 11:02 pm | #31 |
Only the E34Ls.
23rd Dec 2011, 11:06 pm | #32 |
Allright, I'm going to measure them.
Might the different voltages from before be because the pre-amp valves were not installed? If so, sorry. I'm a novice on valve amps. |
23rd Dec 2011, 11:09 pm | #33 |
You need to have all valves installed when taking readings. The reason for this is that more valves consume more current, which causes the High Tension (HT) voltage to fall. Similarly if you have fewer valves installed the HT voltage will rise.
23rd Dec 2011, 11:12 pm | #34 |
Note: The amplifier isn't connected to an audio source and their are no speakers connected to it.
socket 1 | pin voltages: 3# 434 VDC 4# 435 VDC 5# -38 VDC 8# 0V socket 2 | pin voltages: 3# 433 VDC 4# 434 VDC 5# -36 VDC 8# 0V socket 3 | pin voltages: 3# 433 VDC 4# 434 VDC 5# -37 VDC 8# 0V socket 4 | pin voltages: 3# 434 VDC 4# 435 VDC 5# -37 VDC 8# 0V And again on every pin 8 the voltage is 0 |
23rd Dec 2011, 11:16 pm | #35 |
Very good.
Please connect some speakers. It's kinder to the output transformers. You will notice that the bias voltage on pin #5 of socket #2 is lower than that on the other valveholders. This will cause any valve plugged into that socket to consume more current than it would if plugged into say socket #1. Do you have instructions for setting the bias?
23rd Dec 2011, 11:18 pm | #36 |
Don't run the amp with no speakers attached, you will damage the output transformers!
Mark |
23rd Dec 2011, 11:21 pm | #37 |
Thx, I will go and get my speakers. I didn't know it could harm the output transformers.
I don't know how to set the bias, but guessing it would have something to do with "fine tuning" the variable resistors… Do I need to re-test every voltage with speakers or not? |
23rd Dec 2011, 11:23 pm | #38 |
I have to sign off now. You could try adjusting the bias on #2 valveholder. Monitor pin 5 and adjust the bias control so the voltage increases ie goes more negative. This should make the valve consume less current and stop the anode glowing so much.
If this amp is sold as a kit the instructions should be available somewhere and will describe how to set the bias. It may be simply set to give a specified grid voltage, or the bias may have to be adjusted to give a specified anode current. To measure anode current you'd need to connect an ammeter in series with the anode circuit. No need to recheck the voltages with speakers connected, as we've been measuring voltages with no input signal.
23rd Dec 2011, 11:33 pm | #39 |
Ok, Thank you for you're help!
I will make the bias equal to the -38V like valve 1, does valves 3 & 4 also need to be -38V or may they stay as is? The book doesn't mention the bias, only showing pictures as a circuit guide. It's a kit from China… What would the anode current be (an educated guess)? Oh, and if the bias is adjusted. Do I need to replace valve #2? It looks a bit burned from the overheating… Cheers! |
23rd Dec 2011, 11:40 pm | #40 | |
An open circuit electrode (g1) or a gassy tube could cause the fault you describe, whilst still giving "normal" meter readings. You need to find a way of measuring the current through each valve, this is usually done by measuring the voltage across the cathode resistor and applying ohm's law. It would be worth adding these if not already fitted, 10 ohms would be a suitable value. I would guess the standing cathode current should be around 60 - 65 ma's per valve Does the fault occur immediately or gradually over time maybe one hour? Does the faulty valve glow purple on the inside? What colour is the getter flash at the top of the valve? It should be shiny, brown or dull grey is a bad sign. Has the amplifier been dropped at any time? Thanks, Rob.
We have done so much, for so long, with so little, we are now qualified to do anything with nothing. Last edited by glowinganode; 23rd Dec 2011 at 11:50 pm. |
