1st Feb 2019, 4:55 pm | #21 | |
Re: Audio trafo open cct? any fix?
You could try 100 ohms to 1k ohms and see what happens. b - Knowing when to stop or take a step back is always tricky... Alan |
1st Feb 2019, 9:53 pm | #22 |
Thanks Alan & Frank for your good suggestions.
However before going down the alternate feedback route I asked Ed Dinning about an idea to add the missing turns on the outside of the trafo, he gave it approval and suggested the number of turns to use (cheers Ed!)so that's what I did. I stripped the trafo core and added 50 turns on the outside, tapped onto secondary winding. It was guesswork to figure out the winding direction, get it wrong it would have provided positive feedback instead of negative. Anyway I got lucky in the coin toss and it worked, no more howling feedback and it can take full volume. I love this stuff, it's especially satisfying when something like this happens. Cheers
Regards Ray |
1st Feb 2019, 9:57 pm | #23 |
Well done Ray, that's a very good work around.
John Joe. |
1st Feb 2019, 10:18 pm | #24 |
Thanks John Joe, I'm very happy with it.
It was a tight squeeze to get the E laminates back in place over the core, had to gently squeeze the core in a vice to make it 1 mm thinner !
Regards Ray |
2nd Feb 2019, 9:15 am | #25 |
Chapeau Ray!
2nd Feb 2019, 1:56 pm | #26 |
A howl indicates positive feedback and the volume control is in the loop. The feedback could be audio or RF/IF with rectification in the audio amplifier.
I would look at the bypassing of the HT, screen and agc lines. If the feedback is RF/IF then a small capacitor (1nF) across the volume control and another between grid and cathode of the EL84 may work. I do not have a BX548A diagram on the CD to look up Check the voltages on the new EL84. Previously there was a positive voltage on the EL84 grid, this is wrong. Oscillation could give a negative EL84 grid voltage, at least there is a grid stopper. |
2nd Feb 2019, 4:37 pm | #27 |
Thanks Travor,
The feedback has stopped since I repaired the secondary winding. But regarding the positive voltage on the EL84 grid, that was measured with a faulty EL84 in pace. But now I have replaced the valve I will re-check the voltages and see how it's looking.
Regards Ray |
