Old 19th May 2017, 7:51 pm   #1
fast eddieg
Default Scopex 4D 10 oscilloscope.
I will try again to enter a thread. Last time I tried I hit a key and it all vanished.
I would like some help with my Scopex oscilloscope 4D10, which I have the circuit diagram for. The scope trace just went dead while in use. The only sign of a trace now is when turned off the spot moves to the tube centre just like an old CRT TV. The circuit board all looks fine and clean and I do get -1000v on the EHT at D607. I am reluctant to go poking about without some direction, so look forward to all your comments and help for a learner. Thanks Ed.
fast eddieg is offline
Old 19th May 2017, 9:04 pm   #2
WaveyDipole
WaveyDipole's Avatar
Default Re: Scopex 4D 10 oscilloscope.
First thing to check is usually is all PSU line voltages. You mentioned you checked HV and you have -1000v, but have you checked all of the low voltage lines? Are they consistent with what the service manual states they should be?
WaveyDipole is offline
