23rd Aug 2022, 9:25 pm | #1 |
Controlling the HF-150
A recent HF-150 keypad interface repair thread started by Steve G4WCS veered off into a conversation about how to computer control the receiver by sending signals to it via the keypad input connector. At the same time, another forum member appeared with another faulty HF-150 so I have started this thread to continue on with the discussion about controlling these receivers.
Jez provided some extremely valuable scope shots of some typical frequency-change code sent by an original Lowe IF-150 interface and I find that I can decode them by eye now. Key to understanding these is the keycode table from the HF150 'Technical Supplement' - I've come across this before because I used the info to get my homebrew HF-150 keypad going, but it turns out that the same 5-bit codes are used to represent the same characters in the data bursts from the IF-150 computer interface as well. See the table, image #1. The first thing you may well ask is why not just send 00000 for "0", 00001 for "1", 00010 for "2", and so on? I think this goes back to the fact that the first version of the HF150 keypad used an off the shelf remote control transmitter chip which had this character table baked into its hardware. Having been forced to accommodate that code table for communications from the keypad the decision was obviously made to keep the same code -> character table for the IF-150's communications with the HF-150 as well. Image #2 is one which jez posted in the other thread, it shows the first (white) and second (yellow) data bursts of six to change the frequency to 5489KHz. We see that the format of every data burst is the same, there are three 'header' pulses whose leading edges are separated by time T2, then there is a fixed interval T3 between the leading edge of the third header pulse and the leading edge of the first of the six data pulses. I say six, but these six pulses altogether only represent 5 bits, because it is the interval between their leading edges which determines the bit values. T4 (Longer) signifies a binary '1', T5 (shorter) signifies a binary '0'. Because of this, the overall length of a data burst varies with the data value being transmitted. A data burst with the value '00000' will be the shortest, a data burst with the value '11111' will be the longest. We then have another interval of T3 between the leading edge of the last data pulse and the leading edge of the final pulse. If I decode the whole of the six-burst packet which jez posted as pairs (1+2, 1+3, 1+4, 1+5, 1+6) the transmitted characters come out as "05489#", "#" being 'enter'. I haven't confirmed it yet but it looks as though the first five characters are the frequency to enter including any necessary leading zeros, terminated with the sixth character, 'Enter'. I have yet to look at the 8-character frequency setting message which can be used to set the frequency with a finer degree of resolution. Before I go any further I would appreciate it if jez would be so kind as to measure the following time intervals as accurately as possible - not urgent, jez, but it would be great if you would be able to do this some time. T1 (The width of a single pulse, from leading edge to trailing edge) T2 (The interval between the leading edge of one header pulse and the leading edge of the next header pulse) T3 (The interval between the leading edge of the last header pulse and the leading edge of the first data pulse). I believe the interval between the leading edge of the sixth data pulse and the leading edge of the final pulse is also T3. T4 (The interval between the leading edges of the pulses defining a logic '1') T5 (The interval between the leading edges of the pulses defining a logic '0') T6 (not shown on the image). The interval between the leading edge of the final pulse in one data burst and the leading edge of the first header pulse in the next data burst. |
24th Aug 2022, 10:28 am | #2 |
Re: Controlling the HF-150
and the results are.........
T1 (The width of a single pulse, from leading edge to trailing edge) (0.305 mS) T2 (The interval between the leading edge of one header pulse and the leading edge of the next header pulse) (3.040 mS) T3 (The interval between the leading edge of the last header pulse and the leading edge of the first data pulse). I believe the interval between the leading edge of the sixth data pulse and the leading edge of the final pulse is also T3. (6.080 mS) T4 (The interval between the leading edges of the pulses defining a logic '1') (3.020 mS) T5 (The interval between the leading edges of the pulses defining a logic '0') (2.040 mS) T6 The interval between the leading edge of the final pulse in one data burst and the leading edge of the first header pulse in the next data burst. (40.00 mS) Also attached zip containing above summary and scope cursor screen shots for each measurement. Good work Sirius ! I'm thinking of applications for this already. Deluxe scanning keypad anyone ? Jez |
24th Aug 2022, 11:14 am | #3 |
Very quick work, thanks jez. I had a suspicion that T2 and T4 were probably the same and they are really close, so I suspect that the same timing is used for both.
I looked at your original capture of a complete 8-burst packet (FRQ_17.PNG) for a fine tuned frequency but unfortunately some of the pulses are blobbed together in the image and can't be 'read' in the way that I read the more detailed one in my previous post. If you get a chance could you recapture the last four of the eight bursts for the same 'long' frequency in sufficiently high resolution to be 'read' so we can see exactly how the fine tune information is sent. The info in the keypad table appears to say that the fine frequency data is an 8-bit value, which is strange when all of the other packets are 5-bit. |
24th Aug 2022, 12:23 pm | #4 |
No prob.
For completeness I've attached screenshots for all 8 of the data bursts for the FRQ 28734.324 example so you can animate your way through them. Yes, it's strange that they used an alternative strategy for the "high resolution" frequency entry. Kind of blows my original idea of dividing the user entered frequency (with or without a decimal point) by 8Hz (the minimum resolution of the HF-150's tuning) and just outputting a tuning offset number. Are you ok with the other examples for mode change and memory management - whilst I've got the test rig set up ? Jez |
24th Aug 2022, 12:40 pm | #5 |
You've already gone above and beyond the call of duty today, thanks for all your time and patience... will look at the captures in your last post when I have time later (at work just now).
I think the ones for mode change and recall from memory are quite straightfoward as both of those are also supported by the keypad, or at least the V2 version of the keypad. I should be able to get the mode-select facility (hold down CANCEL while pressing a numeric key) working on my homebrew PIC based HF-150 keypad at some point as well. |
24th Aug 2022, 1:26 pm | #6 |
All right, I couldn't resist having a look... so the first six bursts are a standard 5-digit + 'enter' frequency change, and then the 7th burst is 11111 ('Set fine tune') and the 8th burst has a non standard nine data bit delimiting pulses representing 8 bits in the intervals between them. Thanks for anticipating that I would want to know the interval between the 6th and 7th bursts, incidentally.
The 8-bit 'fine set' value which somehow represents the post-decimal '.324' portion of the long frequency 28734.324 is 01010010 which translates to 52 hex or 82 decimal. Bearing in mind that the actual tuning resolution is in steps of 8Hz, so any frequency entered is converted to the nearest 8Hz step, I find that:- (82 decimal x 4) = 328, which is one of the nearest 8Hz steps to .324. It could also have been rounded down to 320, but was rounded up to 328 instead. Of course I could just be choosing the formula which conveniently gives me the answer I want, so the next step would be to capture several more eighth bursts with just the post-decimal portion of the frequency changed to other values. If the same multiply-the-fine-value-by 4 dodge works for other post decimal values then you won't have been far off the mark when you anticipated that something like this sort of calculation might be used, but only for defining the sub-1KHz portion of the frequency. |
24th Aug 2022, 3:26 pm | #7 |
24th Aug 2022, 3:44 pm | #8 |
Four or five semi random values between .001 and .999 would be good, and maybe at least one of them an exact multiple of 8 and two others which are +1 and -1 from an exact multiple of 8, any others to be random, within the from-to range specified.
How about offsets of.... .192 .623 .833 .053 .986 |
24th Aug 2022, 7:33 pm | #9 |
Ok, results attached with a couple of extra examples.
Observations 1) Burst 7 appears to be constant as in "the next burst is going to be the fractional part". 2) A mantissa <= .003 results in a standard, integer frequency, six burst. An eight burst is only output when the mantissa >= 0.004 Jez |
24th Aug 2022, 9:54 pm | #10 |
Thanks Jez -
See if you (or anyone else) can reconcile these burst-8 data values with their associated frequency offsets. Code:
Scope Fraction of KHz Burst-8 As Hex As Decimal Capture Data value Image in binary 8B_01.png FRQ 0.192<c/r> 00110001 31 49 8B_02.png FRQ 0.623<c/r> 10011111 9F 159 8B_03.png FRQ 0.833<c/r> 11010101 D5 213 8B_04.png FRQ 0.053<c/r> 00001101 0D 13 8B_05.png FRQ 0.986<c/r> 11111100 FC 252 8B_06.png FRQ 0.123<c/r> 00011111 1F 31 8B_07.png FRQ 0.345<c/r> 01011000 58 88 8B_08.png FRQ 0.678<c/r> 10101101 AD 173 8B_09.png FRQ 0.910<c/r> 11101000 E8 232 |
24th Aug 2022, 10:20 pm | #11 |
Hello Jez and Sirius
You are doing some very good work here. I am the owner of the LoweHFReceivers group at groups.io. We have archives of the two previous Yahoo groups, but I do not remember any discussion on the serial interfaces at this level of detail. I can explain 7 of the 8 bits in the 8th burst. First of all, the Lowe HF-150 does not tune in 8 (= 1000 / 125) Hz steps, but in 1000 / 128 = 7.8125 Hz steps. The decimal value = INT(last three digits * 0.128). Going down the list 0.192 24.57 0.623 79.74 0.833 106.62 0.053 6.78 0.986 126.20 0.123 15.74 0.345 44.16 0.678 86.78 0.910 116.48 If you look at the first seven digits reading left to right, you will see that they are the binary values of the above decimals. That leaves the right hand or 8th binary digit. It does not look like a parity bit. It does seem to match whether the decimal value after the decimal point is greater than (= 1) or less than (= 0) 0.5 HTH and 73 John KC0G / M0KCY Edited the decimal values to add the values after the decimal point. Changed interpretation of the 8th binary digit. Last edited by John KC0G; 24th Aug 2022 at 10:42 pm. Reason: content change |
24th Aug 2022, 10:20 pm | #12 |
Same table again, but with the addition of the nearest 8Hz step to the fraction of a KHz entered. What we need to do is work out how the decimal number in the 'As Decimal' number column represents the frequency offset in the 'nearest 8Hz step' column.
Code:
Fraction of KHz Burst-8 As Hex As Decimal Nearest 8Hz step Data value in binary FRQ 0.192<c/r> 00110001 31 49 192 FRQ 0.623<c/r> 10011111 9F 159 624 FRQ 0.833<c/r> 11010101 D5 213 832 FRQ 0.053<c/r> 00001101 0D 13 056 FRQ 0.986<c/r> 11111100 FC 252 984 FRQ 0.123<c/r> 00011111 1F 31 120 FRQ 0.345<c/r> 01011000 58 88 344 FRQ 0.678<c/r> 10101101 AD 173 176 FRQ 0.910<c/r> 11101000 E8 232 912 |
24th Aug 2022, 10:42 pm | #13 |
That information about the increments being 7.8125 is rather critical John, thanks. I don't know where I got 8Hz from. I've just caught your further edits to post #11 so I am still playing catch-up.
24th Aug 2022, 10:47 pm | #14 |
Sorry. We are trading posts here. I just edited my post of 4.20pm. It might provide an explanation.
The 8Hz step is a good first order approximation in a discussion of tuning rates. We need more accuracy here. |
24th Aug 2022, 11:35 pm | #15 |
Well, armed with the new info regarding the step size I have now generated a new table.
In column one, all possible 7-bit values of bits 7-1 of the eighth burst, as decimal. In column two, the frequency offset generated by multiplying the value in the first column by 7.8125 Hz. In the third column are the occasional offset values requested by jez when he was capturing that info for us. Along with those in the fourth column is the difference in Hz between the requested frequency and the selected frequency - always less than 7.8125Hz, and for the frequencies tried at least, always on the low side of the requested frequency. Code:
Bits Times by Frequency Difference 7-1 7.8125Hz Offset (Hz) (Hz) between of requested requested eighth Through Offset and burst IF-150 Actual offset as decimal 0 0 1 7.8125 2 15.625 3 23.4375 4 31.25 5 39.0625 6 46.875 053 -6.125 7 54.6875 8 62.5 9 70.3125 10 78.125 11 85.9375 12 93.75 13 101.5625 14 109.375 15 117.1875 123 -5.8125 16 125.0 17 132.8125 18 140.625 19 148.4375 20 156.25 21 164.0625 22 171.875 23 179.6875 24 187.5 192 -4.5 25 195.3125 26 203.125 27 210.9375 28 218.75 29 226.5625 30 234.375 31 242.1875 32 250.0 33 257.8125 34 265.625 35 273.4375 36 281.25 37 289.0625 38 296.875 39 304.6875 40 312.5 41 320.3125 42 328.125 43 335.9375 44 343.75 345 -1.25 45 351.5625 46 359.375 47 367.1875 48 375.0 49 382.8125 50 390.625 51 398.4375 52 406.25 53 414.0625 54 421.875 55 429.6875 56 437.5 57 445.3125 58 453.125 59 460.9375 60 468.75 61 476.5625 62 484.375 63 492.1875 64 500.0 65 507.8125 66 515.625 67 523.4375 68 531.25 69 539.0625 70 546.875 71 554.6875 72 562.5 73 570.3125 74 578.125 75 585.9375 76 593.75 77 601.5625 78 609.375 79 617.1875 623 -5.8125 80 625.0 81 632.8125 82 640.625 83 648.4375 84 656.25 85 664.0625 86 671.875 678 -6.125 87 679.6875 88 687.5 89 695.3125 90 703.125 91 710.9375 92 718.75 93 726.5625 94 734.375 95 742.1875 96 750.0 97 757.8125 98 765.625 99 773.4375 100 781.25 101 789.0625 102 796.875 103 804.6875 104 812.5 105 820.3125 106 828.125 107 835.9375 108 843.75 109 851.5625 110 859.375 111 867.1875 112 875.0 113 882.8125 114 890.625 115 898.4375 116 906.25 910 -3.75 117 914.0625 118 921.875 119 929.6875 120 937.5 121 945.3125 122 953.125 123 960.9375 124 968.75 125 976.5625 126 984.375 986 -1.625 127 992.1875 Last edited by SiriusHardware; 24th Aug 2022 at 11:40 pm. |
24th Aug 2022, 11:35 pm | #16 |
The main HF150 synthesiser tunes in 1kHz steps, with the interpolation oscillator filling in the gaps.
Looking at the numbers, it appears to use 8 bits, giving 256 steps. 1kHz divided by 256 is 3.90625Hz. Multiplying that by your decimal result gives good agreement with the fraction of kHz. E.g 213x3.90625=832Hz Paula |
24th Aug 2022, 11:45 pm | #17 |
I'll try generating another table (tomorrow) based on that concept. If it works, it gets rid of that troublesome right hand bit that we don't know what to do with.
Great to have such a keen team working on this problem. |
25th Aug 2022, 3:05 am | #18 |
On page 7 of the HF-150 Technical Manual it states that the HET frequency (ie the interpolation frequency) can be controlled in 128 steps across its 1 kHz range, each step being nominally 7.8 Hz. My comment is that this will be set in the firmware, and is independent of the encoder pulses per revolution. The encoder ppr sets the tuning rate, not the tuning resolution.
Looking at SiriusHardware's numbers, and following on from my earlier edited post it seems that: the decimal number = INT(last three digits * 0.256) with a range of 0 to 255 and: the control number = INT(decimal number / 2), with a range of 0 to 127 If this is correct, the sent number uses 8 binary digits, but only the 7 most significant digits are used as the HET control. Please, if Jez were up to doing more tests, these numbers might help: 0.039 kHz, decimal number = 9.984, sent number = 0000/1001 0.961 kHz, decimal number = 246.016, sent number = 1111/0110 Thanks and 73 John KC0G / M0KCY |
25th Aug 2022, 8:09 am | #19 |
Hello 2U2 John KC0G (and now also Paula) !
It's now the morning. I had a quick look at this thread before I went to bed last night to see the comment from John about the 7.8125 Hz tuning steps -- W H A A A T ! This was news to me. I'd always taken the minimum tuning step size to be a nice, round 8Hz (I knew that the rate increased depending on mode and spin rate etc). I went to bed, but not before taking a look at the HF-150 user manual and, in particular, the Circuit Description on page 27 which has a paragraph stating:- "Receiver tuning is achieved by varying the frequency of both the local oscillator and the IF conversion (heterodyne) oscillator. The local oscillator covers 45.030MHz to 74.999MHz in 1kHz steps, and fine tuning is provided by the heterodyne oscillator covering 44.544MHz to 44.545MHz in 128 steps...." Bingo! Light bulb moment (44.545MHz - 44.544MHz) / 128 = 7.8125 Hz I see it now ! This also explains the six versus eight bit burst strategy. If the user enters a frequency in full kHz, this will be applied to the local oscillator (and the hetrodyne osc just zeroed presumably?) But, if a fractional frequency is entered, the integer part (6 burst) will be applied to the local osc, and the fractional part (burst 8) will be applied to the hetrodyne osc. Since realising that, I noticed John's and Paula's later comments - great stuff - we're all thinking on the same lines. Last night I was thinking maybe they just used a lookup table or something to resolve the fractional part but, now, probably not. John, I'll try the 0.039 and 0.961 FRQ commands later this morning. Going to have some breakfast and get the shopping in first ! Cheers, Jez |
25th Aug 2022, 10:55 am | #20 |
Ok, I've attached the final (burst 8 only) output for the 0.039 and 0.961 frequencies requested by John. I've also included scope shots for 0.997, 0.998 and 0.999 so that we can see what happens at the end of the fractional range.
enjoy ! (as they say) |
