Old 4th Nov 2010, 2:14 pm   #1
Palacepounder
Default RTT 56B rotary dial wiring
Have just aquired an RTT 56B telephone.
On examination the 4 wires (brown, red, orange and grey) have been disconnected from the rotary dial.
Does anybody have any idea on which terminals they connect.
I have tried various combinations but to no avail.
There are 4 screw connectors on the dial.
Any help appreciated.
Thanks
Pete
Palacepounder is offline
Old 5th Nov 2010, 12:46 pm   #2
julie_m
Default Re: RTT 56B rotary dial wiring
It should be possible to identify the "pulse" and "dial off normal" contacts using an analogue multimeter -- or a 9V battery, LED and 470Ω resistor.
You will then need a wiring diagram for the phone -- if you're lucky, this may be stuck inside it.
julie_m is offline
Old 6th Nov 2010, 10:43 am   #3
Palacepounder
Thanks for that, the circuit diagram under the base plate has perished but have found copy from a previous post.
May need help with diagram after I,ve metered contacts.
PeteN
