17th Jul 2006, 8:00 pm | #1 |
Pye V4 Sync Discriminator Diodes
The V4/V7 uses a twin diode discriminator to measure the drift between pulses from the LOPT and the line sync pulses from the sync separator. The resulting voltage is used to pull the line oscillator back into step. My set suddenly lost all line sync and I have checked the diodes which are listed as M3s. One has nearly infinite forward resistance on the Ohmsx100 range of an AVO 8. The other looks much more like a diode with forward resistance of a few K. Any ideas of what I could use as a replacement please or are M3s still available?
Nigel |
17th Jul 2006, 10:34 pm | #2 |
Re: Pye V4 Sync Discriminator Diodes
Hello,
The M3 'metal pea' diodes have not been available for a long time. Any small silicon diodes such as a pair of 1N4001 series will make a good replacement. Regards John |
17th Jul 2006, 10:51 pm | #3 |
Hi Nigel
I've got some unused M3s diodes if you want them. Ron |
18th Jul 2006, 8:16 am | #4 |
Hello Ron,
Its a long time since I saw a new one of those! They may be a bit variable due to age. They consisted of a couple of circular selenium rectifier units squeezed into the aluminium case. Contact was not the best when new and caused Pye horrendous problems in the V4 and V14C line sync circuit. They would keep the chassis looking original if a reasonably well matched pair could be found. Regards John. Last edited by Heatercathodeshort; 18th Jul 2006 at 8:30 am. |
18th Jul 2006, 9:36 am | #5 |
Hi to All,
Thanks for the info, particularly that M3s were pretty unreliable when new and why. I have the Pye service book for the V4 and in case of loss of line sync, it immediately points the finger at the discriminator diodes, so that bears out John's comments. I have had to replace all Hunts caps under chassis, as I don't know how to rebuild moldseals in the way that one can with card tube waxed paper caps. Therefore, originality of appearance is not an issue with this set. Given the uncertainty of matching a pair of M3s, I will try a couple of silicon diodes. I have some 1N4007s to hand, although they are probably an overkill, but I will try those. If there is no joy, I will take up Ron's offer. The forum never fails to please. Regards Nigel |
18th Jul 2006, 12:19 pm | #6 |
Hi Nigel, it may be better to use Ge diodes or lower voltage types such as 1N4001. The forward voltage of 1N4007's may be too high for good operation.
Ed |
18th Jul 2006, 12:56 pm | #7 | |
The possible objection to 1N400x series diodes is that they are not designed for high frequency. 10kHz is high frequency in this context. The slow turn off time may give poor performance. I don't know what sort of voltage rating is needed in this circuit but provided it's adequate you certainly won't do any harm by trying what you've got in your junk box. If it works then you've solved the problem. |
18th Jul 2006, 1:37 pm | #8 |
The 1N4007s have done the trick! Line hold is rock solid and there was no need to touch the preset line hold adjustment, so the line oscillator is getting the average voltage it expects. As to the question of high frequency operation, I gather that the junction capacitance is only about 15pF, for what that is worth.
Thanks to all for the very helpful advice. Regards Nigel |
18th Jul 2006, 2:36 pm | #9 | |
Anyway, congratulations on getting it working and also for proving that 1N400x are a good substitute for those discriminator diodes. |
18th Jul 2006, 5:19 pm | #10 |
Don't apologise for the simple explanation, Jeffrey: that's about the level some of us pre-transistor types can absorb. (But I sympathise with the flywheel problem - horror movies from my youth !)
