Old 4th Jun 2021, 10:27 am   #1
mikko rintala
Default Grundig VTVM RV3 Type 6062
Mikko from Finland hi. What kind of meter test probe that meter use?
mikko rintala is offline
Old 4th Jun 2021, 12:12 pm   #2
Andrewausfa
Andrewausfa's Avatar
Default Re: Grundig VTVM RV3 Type 6062
Hei Mikko,
I believe they used a EAA91 diode valve in the probe for AC measurements.
Andrew
Invisible airwaves crackle with life. Or they should do.
BVWS Member
Andrewausfa is offline
Old 4th Jun 2021, 1:22 pm   #3
mikko rintala
Originally Posted by Andrewausfa View Post
Hei Mikko,
Andrew
Hi,i mean what kind probe that use? I don t have it.
Best regairds Mikko
Old 13th Jun 2021, 3:29 pm   #4
6AL5W-Martin
for DCV: 1M Ohms in series.
for ohms: cables
for ACV: Probe with a rectifier tube E91AA ( to test <30V~ ! ) rebuild it.
the both tubes are E80F , can be replaced by EF86
the E91AA is a EAA91, 6AL5, EB91
www.wellenkino.de Vintage Scope restorations
6AL5W-Martin is offline
