26th May 2020, 4:11 pm | #1 |
Akai X200
Can any one tell me whch side of theis leaver in pictures should the tape run if it on the insise the rape slows or stoos if on outside the tape runs ok can any ckeare this for me please.
26th May 2020, 7:02 pm | #2 |
Re: Akai X200
Hello Dorian,
I was going to say that this is the Automatic Stop Lever so outside as per the photos is correct. However I am now confused because if it was the Automatic Stop Lever than it looks far too close to the heads and is in the incorrect orientation ? Could you please do another photo but showing a larger surrounding area. David |
26th May 2020, 7:35 pm | #3 |
Re: Akai X200
Tape lifter for FF/Rew? If it is then tape on the outside.
Lawrence. |
26th May 2020, 10:20 pm | #4 |
Re: Akai X200
Ok i will get a larger area photo tomorrow thanks David and Lawrance
26th May 2020, 11:29 pm | #5 |
Re: Akai X200
Concur with Lawrence, it is definitely the tape lifter arm, so tape on the outside as per the photos is correct, no need now for any more photos for it.
27th May 2020, 8:52 am | #6 |
Re: Akai X200
Ok thank you all
