Old 11th Feb 2019, 12:23 pm   #1
newlite4
newlite4's Avatar
Default Old selenium rectifiers
I have a quantity of old selenium rectifiers. Is there a way of testing them to see if they are worth keeping or should they be assumed too old to use and be disposed of. They may be good to "fill a hole" to maintain originality using a silicon by-pass, but better to be actually used if possible.
Neil
newlite4 is offline
Old 11th Feb 2019, 12:39 pm   #2
The Philpott
The Philpott's Avatar
Default Re: Old selenium rectifiers
As an example i bought an elderly battery charger with 12v/6v/2v tappings, and a big green painted selenium rectifier. We 'scoped the output and it was a perfect full wave rectified trace, such that it was put straight into service. I think that very many of them will be ok. If they look uncorroded suggest energising them, and using a 'scope. If they start to smell switch off and ventilate the room!
Dave
The Philpott is offline
Old 11th Feb 2019, 12:54 pm   #3
Nuvistor
Nuvistor's Avatar
I thought battery chargers used copper oxide rectifiers due to being more suitable for low voltage high current. Probably replaced by silicon now.
Frank
Nuvistor is offline
Old 11th Feb 2019, 12:55 pm   #4
paulsherwin
paulsherwin's Avatar
I don't think it's worth trying to use them in anger, though as you say they might have a cosmetic use.
paulsherwin is offline
Old 11th Feb 2019, 12:57 pm   #5
barrymagrec
The big old ones with fins may be copper oxide, not selenium - and basically, if they work under load fair enough. Not so keen on the small contact cooled types though - they`ll certainly fail sometime soon.
barrymagrec is offline
