12th Nov 2019, 7:25 pm | #1 |
BC-454 Command rx/tx
Hi any one know the size of screws to hold outer covers on the command series rx/tx. a few are missing, I have 4 out of around 60 thanks in advance Mick
12th Nov 2019, 7:29 pm | #2 |
Re: bc 454 command rx/tx
Those are pretty hard to find. You best look for a donor unit.
12th Nov 2019, 8:45 pm | #3 |
Hello Mick
can you post a picture, and if you have a micrometer, measure the thread diameter?
Regards Pete |
12th Nov 2019, 8:59 pm | #4 |
Re: BC-454 Command rx/tx
We (work) are about to scrap a load of BA screws, I can win a few if you like.
12th Nov 2019, 9:02 pm | #5 |
Search this forum as follows and another thread will appear with all the details you need.
‘What are the screws in the "Command Set" ARC-5’ Jim |
12th Nov 2019, 9:11 pm | #6 |
They are 3/48
John. |
12th Nov 2019, 9:13 pm | #7 |
make that 3-48
John |
12th Nov 2019, 9:17 pm | #8 |
Not one of the more normal US "fine threads for attachment purposes", but you may be able to find then within the adverts in Model Engineer, or Model Engineers Workshop.
Ed |
12th Nov 2019, 9:46 pm | #9 |
The 3-48 screws in my ARC5 receiver are of a style known as a binder head. They are 3/16 long and all have a internal star washer under them.
John. |
13th Nov 2019, 4:51 pm | #10 |
If you find a source please let the rest of us know.
13th Nov 2019, 4:57 pm | #11 |
This is the place which is usually recommended on the US forums to supply suitable screws - https://www.mcmaster.com/ - unfortunately they will not deal with non-US addresses.
Andy |
13th Nov 2019, 5:39 pm | #12 |
Amazon lists 3-48 screws as do a number of web vendors, which is where I got some, however the original brass style with black oxide coating and lockwasher seems to be unobtainium.
13th Nov 2019, 9:02 pm | #13 |
I picked up some US thread screws when last in the US
Home Depot and Lowes and even Walmart had some Try and find someone going over or coming over here. I dont get there very often or would offer Seems 3-48 are used on a Gibson guitar and can be found on eBay UK, maybe too long though? Or just type "3-48 screws in UK " into Google Fred |
13th Nov 2019, 10:48 pm | #14 |
I think the difficulty can be finding the correct type with 'binder' or 'binding' heads - wider and flatter than most heads. Ordinary round or cheese heads just aren't right, and I'm not sure will fit in the mounting rack.
Andy |
16th Nov 2019, 2:03 am | #15 |
Tacoma Screw products in Tacoma Washington, USA should have 3-48 screws in stock.
http://www.tacomascrew.com/ Tacoma Screw Products, Inc. 2001 Center St Tacoma Washington USA (253) 572-3444 I have dealt with them for over 30 years now. Good folks there. Likely you will not find the screws with black heads or the attached lock washer, but they have surprised me on what they have several times. Typically the screws come in a container of 50 or 100. They will break containers and sell you just a few also. Their main store is about 70-80 miles from me. Last edited by FrankB; 16th Nov 2019 at 2:09 am. Reason: additional info |
16th Nov 2019, 6:10 pm | #16 |
Google:
Machine screws 3-48 x 3/16 slotted binding headstainless steel Look at Amazon. John. |
16th Nov 2019, 7:37 pm | #17 |
Hi thanks for your ideas just found some from a friend in Canada, a box of 200 of them so have spares Mick
