21st Nov 2010, 7:27 pm | #1 |
Avo transistor tester. What batteries do I need?
Hi All.
Can anyone tell me what batteries I need for an Avo transistor tester. Thanks. |
21st Nov 2010, 9:29 pm | #2 |
Re: Avo transistor tester. What batteries do I need?
In the old AVO CT446 transistor tester the batteries are called U10 batteries, you can for instance find replacement batteries here: http://www.smallbattery.company.org.uk/sbc_u10.htm In the more modern AVO CT166 & CT167 you can use standard 9V batteries but you will most probably need to make new battery connectors as they used PP7 or PP9 batteries with a wider spacing of the electrodes, some of these testers come with single electrodes which you can fit, although it will be tight, on a standard 9v battery. They can be found at the same source as above. I do not have any connection to the source mentioned above and I do not know anything about them, I only know that they are a good source of finding information on old batteries and replacement types!
Martin, Sweden |
