Old 16th Sep 2019, 10:12 am   #1
llama
llama's Avatar
Default Mystery A.M. transformer
This is the transformer in the mystery RF device I recently offered. It has Air Ministry markings that look like 10M/162 or possibly 10A/162. It has about 10.5mm of laminations and the markings on one side are IP and OP with what looks like an unused tapping. On the other side it is marked OS, T2 and IS. I suppose these are all input/output, primary/secondary (apart from the "T2" connection).
Overall size is 5cm lamination length, 3.8cm max winding width and 2.9cm height. Coloured dark brown varnish.
I wonder if, just out of curiosity and a sense of completion, anyone has the appropriate AP that would identify the characteristics of the transformer and/or the equipment it's likely to have come from. Speculation welcomed!
Graham
Half my stuff is junk - trouble is, I don't know which half!
llama is offline
Old 16th Sep 2019, 10:40 am   #2
Keith
Keith's Avatar
Default Re: Mystery A.M. transformer
Without checking, it sounds as if it might be one of the transformers from the A1134 intercom amplifier as used in the Lancaster bomber (like the one shown here about 2/3 down the page):
http://www.tibblestone.com/oldradios...adio/T1154.htm
If so, I'm afraid one or more of the windings is likely to be o/c.
Keith Yates - G3XGW
VMARS & BVWS member http://www.tibblestone.com/oldradios/Old_Radios.htm
Keith is offline
Old 16th Sep 2019, 11:13 am   #3
M0FYA Andy
More likely 10K/162.
This is shown in AP1086 as a Transformer Type 285, LF Output, overall ratio 1:2
Andy
M0FYA Andy is offline
Old 16th Sep 2019, 11:45 am   #4
Jon_G4MDC
Jon_G4MDC's Avatar
Would those need a beehive trimmer capacitor and what looks like an inductor with an adjustable core at bottom left?
Jon_G4MDC is offline
Old 16th Sep 2019, 11:52 am   #5
ms660
ms660's Avatar
The chassis look like an electrickery backing box...
Lawrence.
ms660 is offline
Old 16th Sep 2019, 12:17 pm   #6
AC/HL
AC/HL's Avatar
It is: https://www.vintage-radio.net/forum/...d.php?t=159770
AC/HL is offline
Old 16th Sep 2019, 12:33 pm   #7
ms660
ms660's Avatar
A 10K/162 transformer was used in the R1147 receiver.
Lawrence.
ms660 is offline
Old 16th Sep 2019, 1:06 pm   #8
ms660
ms660's Avatar
As a guess it might be for IFT alignment?
Lawrence.
ms660 is offline
Old 16th Sep 2019, 1:06 pm   #9
M0FYA Andy
Well spotted!
Andy
Old 16th Sep 2019, 1:09 pm   #10
ms660
ms660's Avatar
Thanks to a Radio Constructor archive.
Lawrence.
ms660 is offline
Old 16th Sep 2019, 1:17 pm   #11
Jon_G4MDC
Jon_G4MDC's Avatar
Ah I see, a transformer re-used for a spot of home brew. Sorry I took a while to catch on.
Old 17th Oct 2019, 6:09 pm   #12
mickm3for
Thanks for device this is the circuit and valve line up pin numbers match resistor at top ht to anode is 56k
any one a clue as to where the green and the green/red wire would go also ideas on what it is ? thanks Mick
mickm3for is offline
Old 17th Oct 2019, 6:28 pm   #13
G6Tanuki
G6Tanuki's Avatar
If the green wire is connected to the red/green wire, the double-triode becomes a "cathode-coupled oscillator" whose frequency is determined by the coil and capacitor.
G6Tanuki is offline
Old 19th Oct 2019, 12:36 pm   #14
mickm3for
Hi thanks connected green to red green fitted ECC81 6v+200v ht and got a carrier on 1.45 mhz . the other stage i would think is a af osc ? (does not work) caps way off value/oc so transformer is used as a modulation transformer. i would think this is an alignment aid or a marker osc. Will recap and retest Mick
Old 19th Oct 2019, 1:02 pm   #15
G6Tanuki
G6Tanuki's Avatar
Yes the other stage is an audio oscillator - like you said it's set up to tone-modulate the RF-oscillator, so your 'thing' is indeed probably an alignment-aid/test-signal-source for the medium-wave band.
G6Tanuki is offline
Old 19th Oct 2019, 4:49 pm   #16
G3VKM_Roger
G3VKM_Roger's Avatar
Or maybe a "pantry" transmitter so you can play recorded music or programmes onto a vintage RX?
73
Roger
G3VKM_Roger is offline
