15th Oct 2019, 5:14 pm | #1 |
Piezo element
Why are there 3 wires to an extract from a smoke detector ? I want to use in a simple crystal set with small amp.
15th Oct 2019, 5:52 pm | #2 |
Re: Piezo element
I don't understand your question. Any pictures?
15th Oct 2019, 6:17 pm | #3 |
Re: Piezo element
My guess is that this is one of those piezo buzzer 'disks'. Some types have 3 connections, a common wire to the metal disk (and thus one side of the piezo-stuff), a large 'drive' electrode on the other side and a smaller electrode on the same size as the large one that can be used for feedback in an oscillator circuit. I seem to recall you can make an beeper with one of these 3-terminal piezo sounder, a transistors and a small number of resistors and capacitors.
If you want to use one as a speaker then use the wire to the disk and the wire to the drive electrode. Either ignore the feedback electrode or connect it to the drive electrode. |
16th Oct 2019, 6:17 pm | #4 |
Re: Piezo element
This is what I meant. How do I know which is which , other than by experiment?
16th Oct 2019, 6:30 pm | #5 |
Re: Piezo element
The colours of the existing wiring and markings where they connect to the detector PCB (which I don't see in your picture) is usually the best clue. More often than not the 'main' connections to the sounder will be red and black and the feedback wire some other 'neutral' colour like white, green or blue.
Have a look at this article, which also includes a standalone circuit to drive such an element. https://electronics.stackexchange.co...a-piezo-buzzer |
16th Oct 2019, 6:36 pm | #6 |
Re: Piezo element
I would think the metal disk is the common connection, the large annular metal part is the drive electrode and the little 'dot' in the middle is the feedback electrode.
I am not sure how you are going to make connections to it (soldering wires to the electodes can damage the piezo-stuff) but I'd try using the metal disk as one connection and the 2 electrodes joined together as the other one. |
16th Oct 2019, 7:31 pm | #7 |
Re: Piezo element
I have a couple with wires on if you need one and several minature speakers if preferred for the cost of postage.
Andy.
22nd Oct 2019, 2:24 pm | #8 |
Re: Piezo element
Thanks all of you . I have sorted myself out now.
22nd Oct 2019, 3:17 pm | #9 |
Re: Piezo element
If you make an oscillator, or make a signal with software on a microprocessor and feed it to a piezo transducer, you run into the problem of making sure the drive frequency is on the resonance of the transducer for best output.
Using the transducer's resonance to control the frequency is an elegant way round this problem. All you need is an amplifier the small sense electrode drives the amplifier and the amplifier drives the big electrode. It goes unstable and ocillates bang on its own ideal frequency. David
