Old 13th Dec 2019, 12:04 am   #1
tircarradio
Location: Fivemiletown, County Tyrone, Northern Ireland, UK.
Default Trying to find info on a vintage radio
I am trying to find the make of this radio. It says British made model 765B but I can’t find a make. Any ideas would be welcome. I am hopefully going to try and restore it.
ID:	195272   Click image for larger version
ID:	195273   Click image for larger version
tircarradio is offline
Old 13th Dec 2019, 1:48 am   #2
lloydwells
Default Re: Trying to find info on a vintage radio
It's a Multitone made by Multitone of London a hearing aid manufacture by the look of it
lloydwells is offline
Old 13th Dec 2019, 9:33 am   #3
tircarradio
Default
Thanks for that
Also would you have any idea where I could get wiring diagrams for this model. i have tried searching but no success
Old 13th Dec 2019, 5:54 pm   #4
lloydwells
If it's a multitone you won't get a schematic pop the back off and put some photos on here
Old 14th Dec 2019, 12:04 am   #5
Dave757
There's a Mutitone valved 'Deaf Aid Receiver' on Paul Stenning's disc 3.
Although it isn't the same model, having 3 front panel controls against
4 on the one pictured above, it may of course share similar circuitry
Kind regards
Dave
Dave757 is offline
Old 14th Dec 2019, 1:01 am   #6
AC/HL
AC/HL's Avatar
tirrcaradio, can you remove the back panel and post some more photographs.
AC/HL is offline
Old 14th Dec 2019, 12:35 pm   #7
60 oldjohn
Originally Posted by Dave757 View Post
Kind regards
Dave
Also available top right of this page for £1.99, maybe worth a look.
John.
My favourite text message "I'll be there in five minutes, if not read again"
60 oldjohn is offline
Old 14th Dec 2019, 2:02 pm   #8
David G4EBT
David G4EBT's Avatar
Kind regards
Dave
It might help identify if there are any similarities of that set and yours by looking at the valve line up.
The one on Paul's DVD-ROM (and at the top right of this page) is an all wave radio (L/M/SW) and 'deaf-aid' amplifier, using nine valves.
The line-up is as follows:
V1 6K8G
V2 6K7G
V3 6Q7G
V4 6K7G
V5 6Q7G
V6 6F6G
V7 6F6G
V8 5Z4G
V9 EM34 (Magic Eye).
It's quite a complex set with a powerful push-pull audio stage.
In some respects, a rather curious set which no doubt fulfilled a need, and I dare say would be been costly to buy. When switched to the 'hearing aid' amplifier position, the frequency changer and IF stages are disconnected, as is the magic eye. In that position, V4 is a microphone amplifier for a crystal mike.
Your set might be nothing like that one of course when you take a peep inside, but it's the only Multitone set listed.
Hope that might help a bit.
David.
BVWS Member.
G-QRP Club member 1339.
David G4EBT is online now
Old 16th Dec 2019, 7:35 pm   #9
tircarradio
Thanks for all the replies above. I’ve had a look inside and attach a few photos of the setup. Only 5 valves in there I’m afraid. I hope to get the whole chassis removed and cleaned up to see if there are any clues as to the make etc.
ID:	195478   Click image for larger version
ID:	195479   Click image for larger version
ID:	195480   Click image for larger version
Old 19th Dec 2019, 6:05 pm   #10
allan
allan's Avatar
Location: South coast near Ringwood/Christchurch, Dorset, UK.
There might be a date on that aluminium capacitor at the back?
Allan
allan is offline
Old 21st Dec 2019, 8:02 am   #11
Silicon
There might be a clue on the dial glass.
Sometimes there is small text or a part number printed onto the glass to identify the artwork.
You may need to remove the chassis from the case to see it.
Silicon is offline
