Old 23rd Jan 2019, 1:58 pm   #1
stuartfurbank
Default Racal RA1772 IF Crystal Filter profiles. Testing. Help wanted.
I am testing a number of 1.4Mhz I.F. Crystal Filters as used on the Racal RA1700 series radios, RA1772, with a Spectrum Analyser and Traking Gene.
I have tested a number of symmetrical filters and all have a similar shape, profile and the Spectrum Analyser displays the corresponding BW for each filter tested eg 400Hz 9Khz, 6Khz etc. All OK
However I have one filter marked USB 3Khz, on test, the filter shape/ response is the same as the symmetrical filters (ie non LSB/USB filters).
My Q., is this correct? Or should I see a different shape for this Filter as I assume it should have an Asymetrical response.
Or
Should a USB filter response just be shifted away from the 1.4Mhz centre.?
Any help gratefully received.
Stuart
stuartfurbank is offline
