Old 4th Nov 2019, 9:32 pm   #1
Ed_Dinning
Default Bush DAC90a
Hi Folks, I've just had one of these to repair that looked as if it had only ever had the UL41 replaced and no other work done.
Main fault was a faulty second IFT, duly replaced from a scrap chassis and was found to be almost spot on alignment wise.
It then had the Peter Vaughn mods done and sounds great
Main residual problem is motorboating on LW, no amount of additional decoupling seems to cure it, but no problems when right on station (and fortunately no drift). Any ideas ?
I also carried out my latest mod as I mentioned in another thread; I used 2. 6.3V 60mA lamps, connected in parallel and with a 250R bypass resistor. Result is reasonable brightness and no sign of lamps dying if rapidly switched.
I think these lamps are readily available, I had them as HT fuses for battery sets.
Ed
Ed_Dinning is offline
Old 4th Nov 2019, 11:03 pm   #2
Piccy2valve
Default Re: Bush DAC90a
Hi Ed,
Just starting my first radio repair attempt a dac90a curious what the Peter Vaughn mods are
Regards mark
Piccy2valve is offline
Old 4th Nov 2019, 11:09 pm   #3
DangerMan
Hi Mark,
Modifications are described here:
https://www.vintage-radio.net/forum/...ad.php?t=35784
Pete
DangerMan is offline
Old 5th Nov 2019, 10:07 am   #4
DonaldStott
DonaldStott's Avatar
Thanks Pete - it's easy once you know that Peter Vaughn is Forum member kalee20.
In relation to these mods I can only agree with the comment from stevekendal in the linked Thread "Wonderful piece of research and immaculate wiring there, makes my own fumblings look rather crude"!
@Ed_Dinning (or anyone) - I'm still none the wiser as to what is meant by "motorboating" and what is sounds like. I've always thought there is a place for a Sticky with links to audio samples on what common problems sound like?
When I have the time I must go back and revisit my DAC90A - although it's working the scale lighting is very dim, there is a residual hum and the treble response is poor.
BVWS Member
DonaldStott is offline
Old 5th Nov 2019, 10:26 am   #5
G4CMY_Tony
In my view, "motor boating" is a pulsing, low frequency oscillation that sounds a bit like the motor on a small boat.
Tony G4CMY
G-QRP-C No 57
FISTS No 1626
G4CMY_Tony is offline
Old 5th Nov 2019, 12:11 pm   #6
ms660
ms660's Avatar
An example of motor boating:
https://www.youtube.com/watch?v=MDIuVFiVIKo
Observant ones might be able to catch the the IF birdies.
The time periods are often governed by the time constants in the AGC circuit.
Lawrence.
ms660 is offline
Old 5th Nov 2019, 1:32 pm   #7
DonaldStott
Thanks Lawrence
BVWS Member
Old 5th Nov 2019, 1:57 pm   #8
kalee20
Good to know there's another modified DAC90a out there - thanks Ed!
Thinking in writing... motorboating is often caused by inadequate HT rail decoupling, causing feedback at AF from a later stage to an earlier stage via HT rail common impedance. But that can't be the case here as there are only
two AF stages (UBC41 and UL41) so any feedback would be negative.
Oscillation in the AVC loop? Signal level rises, so AVC voltage increases, but there is a delay in the AVC time constants so the control voltage does not get fed back: by the time it does, the signal level has overshot, the valves start throttling back, the AVC level falls, but the reduction in AVC voltage is again time-delayed. Continuous LF oscillation results. But that would surely be most likely to occur with a strong signal, bang on tune. Anyway, worth checking the AVC series resistors just in case one has gone high.
Variation in frequency in the frequency changer with AVC voltage? Sounds a bit more likely. AVC voltage rises, oscillator frequency moves off-tune, IF signal moves down the IF amplifier response curve, IF signal at the detector falls, so AVC voltage falls. But again there would need to be significant phase shift in the AVC decoupling network.
I'd try forcing an external negative bias (9V battery and potentiometer) onto the AVC line, to overcome the radio's own AVC, and see what happens. Maybe a frequency counter picking up the IF signal would help.
kalee20 is offline
Old 5th Nov 2019, 5:20 pm   #9
Ed_Dinning
Hi Peter, thanks for that.
Set was with its original ecap that showed OK for ESR, but I normally add an extra 0.1 or so as ESR tends to rise with frequency.
I think your mods increased AVC cap values a bit. Resistors all checked OK
Donald, hopefully motorboating has now been explained,m you will know it as soon as you hear it.
Piccy, the links to Peters mods were given above. In them he "modernises" the DAC90a circuitry to improve the sound of the set so it is more to modern tastes, rather than "mellow bellow". The reasons are also well explained in the article.
Ed
Old 5th Nov 2019, 7:16 pm   #10
Helder Crespo
Helder Crespo's Avatar
Ed
Hi
Quick question: I'd like to try the output transformer mod this weekend, replacing the 0.01uF with a high-voltage 6.8nF+4.7k. Would a 1/2W resistor be enough, or should this require something larger?
Thanks!
Helder Crespo is online now
Old 5th Nov 2019, 7:21 pm   #11
kalee20
Larger. But for trial purposes 1/2W will be OK.
It's only going to dissipate significant power if you listen to material with a lot of treble content, and you have the volume well up. The maximum it would dissipate is what the UL41 can throw out, i.e. 2.5W in the DAC90a, so if you like it and buy a resistor for permanent, go for a 3W type.
kalee20 is offline
Old 5th Nov 2019, 7:28 pm   #12
Helder Crespo
Thanks! I definitely would like to go permanent in case I'm happy with the perceived treble response. I will test it with a modern source - the output of a bluetooth module - which is part of a totally reversible mod in my second DAC90A. I would not expect much change from an AM source, although I could be wrong in the light of your description in the thread referenced above.
Old 5th Nov 2019, 7:53 pm   #13
Ian - G4JQT
Ian - G4JQT's Avatar
Sounds like the 'fault' on my completely rebuilt Ekco A22 when using my pantry tx. Only motorboats on that strong station at high volume. Lots of extra HT decoupling fixes it, but that shouldn't be necessary.
Ian - G4JQT is online now
Old 5th Nov 2019, 8:19 pm   #14
Ed_Dinning
Hi Helder, the other mods round the output valve are also worth doing.
Ed
Old 5th Nov 2019, 10:26 pm   #15
Piccy2valve
Dangerman, Thank you for the link, i will look at putting peters mods into my first radio project , the dac90a that i am starting now
Old 6th Nov 2019, 1:04 am   #16
TrevorG3VLF
TrevorG3VLF's Avatar
I wonder whether there is a phase problem. The IF transformer was changed and the phase may have been changed with overall stray feedback changed from negative to positive.
Sometime ago I repaired a set by replacing a chewed up IF transformer secondary with a single tuned transistor transformer top coupled to the primary which probably changed the phase. The set was partially umstable which was cured by cutting the AGC line and adding more low pass filtering. The set had a ferrite bead in the AGC line near the first valve indicating that the design was dubious.
TrevorG3VLF is offline
Old 6th Nov 2019, 10:21 am   #17
Helder Crespo
Ed
Thanks Ed.
Old 6th Nov 2019, 2:54 pm   #18
Helder Crespo
Ed
Hi Ed (and Peter)
These seem easy to do (the hard work was already done by Peter). I have one very practical question: where can I get components around London without having to buy 50 of each or something like that (as with RS and etc.).
Also, could you help me with your recommended power/voltage ratings for each of the new components? Thanks!
Helder
Last edited by Helder Crespo; 6th Nov 2019 at 2:59 pm. Reason: added extra information.
Old 6th Nov 2019, 3:02 pm   #19
John10b
Cricklwood Electronics, North London,is a good source of supplies.
John
John10b is offline
Old 6th Nov 2019, 3:10 pm   #20
Helder Crespo
John
Thanks John!
